Force Performance said::rolleyes: Y not check from Dragger Racing of Sri Damansara at tel: 03-62754508 4 d cheapest turbo-charging modification in KL.
They can bolt-on d rebuilt Garrett T02 turbo with their own make exhaust manifold 2 run a max of 0.6kg/cm boost only 4 d Gen 2 internal light weight designed engine components.
A good used blow-off valve n used VR4 intercooler can be utilized 4 low costing.
Must change 2 larger fuel injectors 2 d original very intelligent Siemen ECU n controls by d very friendly tune PS. Air-Fuel Enhancer, Boost-Cut Eliminator n EGO Pulse Trimmer 4 ideal engine operation.
where is the workshop?? how do you define as cheap?? if i wanto bold on my kelisa, how much do you think it will come out?? Thankz..
