Best place to mount sensors?
Penghanyut
Hello guys,
Wanna enquire a bit from sifus.
Where would be the most practical and accurate place to mount oil temp and oil pressure sensors for VR4? Will it be accurate enough if I were to get the oil press/temp adaptor which is placed in between the engine block and oil filter? Also any issues with oil leaks for those who are using this type of adaptor? Thanks in advance :)
juz buy the adaptor. saw alot of half cut part using adaptor to install sensor.i use adaptor for oil cooler on NA car more then 1 yrs. no leak until now.
If wanna know the oil temp from engine, best easiest place is using adaptor attach with oil filter; If wanna know how efficient is ur oil coller and wat oil temp is actually goes into ur enigne, then put a "T" b4 the oil go into ur engine head.
For oil press, jz put at the filter adaptor enuf.
Write your reply...
