sounds like an idea, but what kind of benefits are you expecting out of it?
Even if you can stuff a B16B crank in, you'd be stuck at finding a proper piston with modified wrist pin height, or using back stock B16A rods,
AFAIK, the b16B block has additional height to accomodate longer b16B rods, while the stroke remains the same. The advantage of having long rods are the fact that it can be revved up without too much concern for wear.
Thats what I think though, but I'm still curious as to what benefits using B16B crank in a B16A block
if ready can include,the cc will same 1595cc only,better u find jun or spoon stroker kit_my fren ek use b16a block but got 1834cc,use toda crankshaft,toda conrod,and b16a piston,toda crankshaft same with b20b got 89mm,just the toda conrod short_so can include to b16a block!!!he buy the stroker kit about rm4xxx complete set
cannot fit.
toda stroker kit rm4k onli???....wow....yet jun stroker is USD3600....
different crank n conrod length. only stroke size is same.mr.hattech, what reason cannot fit?
