Airtrek member in Ipoh
Waiting for the them to b ready bro. Do u an any idea why does the lights dim when ever I use the power window. I feel it even dims n back to normal while driving
Sent from my GT-I9500 using Tapatalk
not so sure why's that happen.. maybe ur power window need lubrication cause it might sucks high current to move.. maybe can install volt stabilizer too..
> Lubricate your power window rubber lining with non-oil based vinyl protectant every 3 months (I use Amorall)
> Check your alternator charge. Best if you have a volt meter.
> Check your battery connection.
> Install grounding (fake HKS cheap grounding around RM15 per set for 5 point grounding)
Airtrek alternator is weak. Mine has similar issue too when power window is operating, headlamp seems to dim a bit. Worse is when I pump my subwoofer, it dims even more (even dashboard light) and in-sync with the bass. So I don't trash the ICE during night driving.
Thanks bro
---------- Post added at 12:33 PM ---------- 6 hour anti-bump limit - Previous post was at 12:32 PM ----------
Assassination Assassination sad sad dad's
Hi, Any one of you selling your rear pair suspension in Ipoh?
huh... but what is the condition?
ur spring still using in ur car?
u in Ipoh?
Condition of the absorbers is used but no leaks or what so ever. I sold the stock springs already. Currently using aftermarkets. I am in KL and not Ipoh. Can send to you via postage.
