Air Filter Comparison..
huakenny said:
my drop-in got sound le....3inch cai...quite loud somemore...:_:
What drop in are u using?? And may i know how u connect your CAI with the air filter box ??
Got sound like BOV but...what?? fuel consumption bad??
cant get other photo since im outstation...
here a photo of a kenari
http://zerotohundred.com/newforums/showpost.php?p=1449831&postcount=22
hmm, can i install the CAI to my original air filter box?? Below are the pic of my current original air filter box. Must modify anything?
can any1 share te pic for heat sheild since is quite important for open pod!!
any materil except metal and any sharp is most suitable ??
Air Filter In 88DB.com
Hey guys, i had just discovered a new website to advertise anything you wish and search for thing you need "FOC". Try this out at www.88DB.com. Cheers!
so wat the relation the the air filter thread?:confused_smile:
the CAI can be done, u can ask Ninja_iga aka Stanley for the correct hose size...2.5" if not mistaken.....
Thanks Kenny, will look into that soon. Btw, how do we determine the size of the filter which suits our car?? And will installing open pod filter significantly increase fuel consumption??
if apexi open port..there is one size only...apexi dual funnel....
if knn, i think 3inch is ok....6inch somehow too big for a wira :_:
installing open port wil not show a significant increase of FC unless u change ur driving habit/style
most owners tend to flow the acceleration pedal more after change the filter coz of the sound/power they get...so the FC wil go up indirectly....
tat y many owners say open port consume FC, but instead it is NOT.
my 2cent...feel free to shoot me if im wrong...:_:
Basically thats very right, i get a lot of shoot back when i say putting in a freeier flow filter gives better performance and if you know how to drive you'll save on FC also, the only problem is no one can resist from flooring when they floor an open pod, they just want to hear the sound and that actually triggers the high fc syndrome, imagine just for listening to the sound, you are actually flooring 30percent more each time, my take is still a drop in for retaining that high end torque feel.
Which wan is better, Apexi or K&N ?? In terms of performance??
You guys got a point there. :regular_smile:
But comparing a drop in vs a open pod, does it mean that open pod contribute more to low end torque as wat ethanphoon592 ur saying that drop in provides more high end torque instead??
bro's.... have a question...
say la got got 3 situations
1. drop in and always floor... how the FC ?
2. drop in never floor, hows the FC ?
3. drop in, occasional flooring, hows da FC ?
4. open pod, never floor, hows da FC ?
5. open pod, occasional flooring, FC how?? same as no. 3 ???
thx alot guys, im thinkin of changin my open pod to drop in, in light of petrol prices and the never ending struggle to go thru da month....
need to do some research b4 investing more money... *sigh*
thx alot guys, appreciate it...
actually jack, i have used both open pod n drop in... i dun feel much difference, except for the sound .. (or maybe coz my drop-in had a reasonably fine CAI n heat insulation thats why) ... so actually, if done with a heatshield/insulation and good CAI ... drop in or open pod is almost the same .... the FC is totally dependant on how heavy is your right foot ... juz that open pod will juz make u wanna floor it more often . heheh.. cheers!
Thats right on nitrus, so guys i can't comment in so detail about your questions regarding your FC behaviour on different driving habits, yup if you pull a CAI hose to your ori box, you'll get good results too, i don't know about the rest but i really feel the emptiness on 3rd gear onwards around the midrange area when using open pod, wherelse with the stock box setup you will still retain the high end torque, the next time just experiment la, try driving at 3rd gear onwards and measure how fast your speedo is going up with open pod and standard airbox with drop in. You'll see the difference, and of course rpm sure fly up faster with open pod but how about speedo?
logic is here when come to chaging AIR FILTER
1st --> cleaner air not good?
2nd --> more air not good?
3rd ---> air is FREE
4th --> no such thing changing air filter will consume more fuel
FC high or not depends on your right foot. Once u bought an AIR FILTER 1 shot bleed la....but u enjoy 1st and 2nd for free for long term.
yeap yeap... after changing mine to K&N filter, my FC improves by 1km/litre....
on highway, my fc now is around 14km/litre.....
Cool...U change ur filter to K&N drop in or open pod type??
my K&N filter photo is at my signature there lo...
FC improve or not also depends on ur car setup and ur right leg....
the FC should be improved after u changed to high performance air filter....less air restriction oledi....ur car breath easier oledi....
so for the FC...it is not solely depends on ur air filter....sumtime bad fc maybe because of dirty tb, spark plug....etc etc
