A32 idle timing
SHIFT_
Hi All masters:
Good day!
Just acquired a used A32 2.0 last month.
My problem/symptom:
On cold start (e.g. in the morning), even if the car has warmed up traveled a certain distance, during idle (say, while waiting the turn of light), the idle timing drops to ~600 rpm (gear shift in "N"). If I restart the car, the idle timing "could" return to normal (~800-900 rpm). I use "could" because this workaround works only 50% of the time.
So far for a month of possession, this happens about 5 to 6 times. Since the forth occurrence of this symptom, I've changed to RON97. It happens less frequent after the change of fuel grade.
What could be wrong? Please help!
Thanks.
sound like my previous problem. 2 actually
vacuum leak and AFM meter spoil
