anybody here?
need help asap
u just post ur problem here. the member will reply once saw the problem...
anybody here?
need help asap
hihihihi, dont forget to bring the 2.1 when we go TT later eh.. i'll be back to KL next week..Calvin,
Dun lah say things like that. =p No question is too small wan la... everybody's learning. I can help I sure help wan... we all still brader brader although I'm ex-4G91 mah. I still will share share knowledge wan. =)
Btw, narrowband O2 sensor memang cannot get accurate readings wan la. It'll oni tell u if its rich or lean. It can't give u accurate readings wan... just estimate only, thats why its called a narrow band, it only detects a small range around 14:1, anything out of that range is labeled very rich or very lean. =p
Wideband sensors have a wider range of accuracy, therefore it can give u better readings away from the 14:1 mark... but wideband sensors are expensive and have very VERY limited lifespan. Thats why people only use it for dyno tuning or track racing to log your engine performance during the race. wideband sensors lasts between 50-500 hours only... depending on the petrol u use and the tuning. LEaded petrol kills the lifespan, running too rich also shortens the lifespan extensively.
Oh, and I'm not joking. I'm driving 1.3 only now... u dun believe, we go out yumcha, I let u check under my hood, if 1.3... then u belanja me teh O ais + nasi lemak la.... leng mou? hehe... old man di mah. =(
Tajul,
GSR and 4G67 are totally different engine designs lah... what would u wanna do with a 4G67? You can plonk in a GSR block yes la... for 4G67 u need the whole halfcut man... =p nothing's gonna fit your 4G67... cept maybe your radiator. That also ur radiator hoses u mite need to change. haha...
well, u just need to tebuk a hole at the extractor & weld a nut the size of the O2 sensor on to that..4G91 change GTi extractor, how 2 settle the o2 sensor position?
u r also here ah bro..downgrade from 1.6 to 1.5?
not downgrade frm 1.6 to 1.5.now sohc wiring wan to upgr.to dohc wiringRe: 4G91 Gang..
Quote:
4G91 Gang....
help needed....looking for 4g91 auto engine wiring n ecu?
currently using 4g92p wiring n ecu...
pm me if item available?
ady-012-6987824
aiyo, i just sold mine to sumone else liau.. no stock for now bro.. u r using sohc??not downgrade frm 1.6 to 1.5.now sohc wiring wan to upgr.to dohc wiring
bro...tajulsans...looking for 4g91auto engine wiring n ecu...how much budget...pls help tq
Any exhaust shop can help u with that..
thx for help.
but i dun like the method.
i think i found a better solution.
Everybody doing & planning to upgrade to other class already, later on only me play this little engine huhuhuhuhihihihi, dont forget to bring the 2.1 when we go TT later eh.. i'll be back to KL next week..
Well, there is reason for everything i planned.. takkan i simply2 wanna do things like that.. do u know that i'm running on Evo engine wiring now, hint*.. For other people, maybe lah need the whole halfcut.. but for me, i got plenty of evo parts in my shop.. thats why i onli need the engine kosong, spare parts i got plenty in my shop bro.. miahahahah.. If u want anything Evo 1-3, let me know.. oh, recently got tomei 260 cams from E3 halfcut.. donno sold edi ka, ur hand itchy or not??
thx for help.
heheheh be "The Last Of The 4G91" pun okay kan?dun wori bro ayel....
ill be ur junior...
hehe
me havent started yet!!!
is there any diff between sohc and dohc wiring???
ur 4g92 is ori proton engine right??
then should b sohc ma...
or u edi change dohc head???
wah...
someone wanna play evo liao....
scary scary.....
oh ya...
settled my a/f reading prob....
got a wiring diagram to confirm the wiring position....
seems like no mistake on previous tapping...
then still not happy...
change the O2 sensor....
then viola!!!!
the a/f reading looks more accurate edi...
cruising around 14.4+-...
but once i full throttle....it will go till 10.....
n if i rev high n lift off....it will go till 20....
2 extremes....
do i need to try another O2 sensor???
wahahahaha
i think cannot coz the hole is much bigger at the intake for mivec than 4g91...just want to clarify...intake manifold mivec can fix 4g91?![]()
hehehe, that is considered a contingency plan la.. kakakka.. not sumthing immediate.. well, i'm not that worried as most of the stuff i got in my shop are dismantled from tested to be in running condi halfcut..Huh? What 2.1?
Wah... u wanna rojak until like that ah? 90% of the time people do that end up with potato engine. Underpowered with very very bad fuel consumption. =p Wanna do things do properly bro. Don't dig your junkyard for leftovers to make a full set. =p Dun believe me try and see lor... =p A lot of people wanna budget budget do that all end up wif potato engines. haha... Trust me, I know quite a fair bit of people who experienced that before... all give up and sell car. =p
E3's Tomer 260 cams can fit my 1.3 ah??
can use la.. but if not mistaken it will shift ur powerband upwards..just want to clarify...intake manifold mivec can fix 4g91?![]()
. It's the whole car going for RM29k nego!
