20V using RON95...no problemo !
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
As Salam and good day...
1) How may of 20V enthusiast here using RON95 and how was it ?
2) How's the FC comparable to RON97
3) How's the power output comparable to RON97
Due to crazy and unacceptable price of RON97...
many asked me...is it ok ? can it be done ? will it damage the engine ?
The answer is yes...
with the right setup, right tuning, the right mechanic...yes it can be done !!!
Feel free to share your experience...
D7zul
2,697
848
Shah Alam
20v designed to be run with RON100.. where 2 get that???
anywayz, they run fine with RON95..
if u ask me.. i use RON95 for everyday use & RON97 if my right foot is itchy.. hehehe :evil:
my conclusion,
RON95 = a lil less power.. juz a lil
RON97 = a lil more power.. little only :biggrin:
chinozie
3,429
170
5,163
Damansara
20V Manual ...
means...your setup is not perfect...ngeh ngeh...
Once tune to run on RON95...then put in RON97...idling or some setup will "lari" one...
it also depends on your engine healthiness ... :driver:
D7zul
2,697
848
Shah Alam
how to tune to RON95?
retard/advance cam?
2slow
431
082
been using ron 95 on bt about 4 years now,so for no problem.if compare with ron 97 sure,ron 97 have more kick not much different on 20v i would say
me2kimi
717
276
1,563
Puchong
I enjoy using Ron95. Not much different with Ron97.
But I know that 2 of my cylinder already lost of compression.
Huhu.
Will try again after my engine overhaul.
nappx
2,532
185
5,163
kLaNG-kEy_tEE
any proven.. he he got diff when using ron 95/97...(based on feeling)
let dyno & see result..he he
KHWONG
3,937
36
1,648
ron 95 = economy drive but need piggy to tune the air fuel mixture
ron 97= can feel the combustion more power than 95.. but not economical at all.. hahaha
Ratbit
75
15
1,508
I guess i had use ron95 for more than a year, first it is o.k for my car,
but lately ....everytime i fill my car with ron95..my engine lights will blink...and the car loose much of its accelerations power.
when i fill it back with ron97 the engine lights still blink, but after a while it will off.
Due to economic factor i have no choice but to use back ron95, and until today, i drive my car with the engine lights blinking..
tHrottle power
57
5
1,508
ever since the launch of RON 95, i ve using it on my BT oredi....once in a while I will pamper it with RON97. I ve used E-Manage to tune the AFR n ignition timing. So far, no complaint...the only dif is that ron95 has lower pick-up power(acceleration). Lesser kick, yet that significant @ me. As my AE111 has pass 200k km, so i ve also change to a new O2 sensor.
D7zul
2,697
848
Shah Alam
Engine light blinking? better start saving some money for new ECU :biggrin:
suma_
303
7
DU
using it since the 1st day of RON 95 in market. during initial pump, definitely no difference since RON 97 left over still in the tank. one significant impact - engine knocking during hard pressed but then the ecu will do adjustment to reduce the knocking. for sure we need a good & healthy ecu to re-adjust and learn ron 95.
in term of power - once your car is regularly pumped with ron 95, it will make no different if you pump ron 97. just from my experience. (SVT 2nd Gen). for daily use - i still manage to get 10km+/liter.
levin818
1,260
321
3,183
Shah Alam
Either using RON95 or 97, will not cause check light to blink.
Check light blinking means your ECU is faulty.
Have it check/replace/rebuilt immediately before it stall your car in the highway.
Not to mention about the towing cost incurs, it will definitely endanger to driver and passenger's life.
---------- Post added at 12:42 PM ---------- 6 hour anti-bump limit - Previous post was at 12:31 PM ----------
Comparing Petronas RON95 xtra and Shell V-power 97 in my BT ride...
RON 95 gives lots of knocking even though at 1st gear. Need to push up the RPM before release the clutch in order to get rid of the anoying click click sound. Poor acceleration and feel like engine is running rough at 4000~8000rpm. However, surprisingly FC is slightly better than 97 (~430km vs ~400km full tank).
tonyops
249
17
518
Sarawak
for my case, the knocking sound is more quiet when I use RON 95. When I use RON 97, knocking sound is quite loud. Does it mean if those people use RON 100 in Japan, the knocking sound is totally gone?
At 1st i thought the fuel quality may contribute to the knocking sound.How can we ger rid of this knocking sound (sounded like typewriter, or diesel engine, tak tak tak tak....never ending sound) ??? I find it rather irritating. Anyone has experienced / know how to get rid of that sound?
D7zul
2,697
848
Shah Alam
AE101 Supercharger :biggrin::driver:
chinozie
3,429
170
5,163
Damansara
I'm assuming the diesel sound appears during engine idling too...not during acceleration...
If do...that particular sound is well known among 20V enthusiast...
It's the sound of VVT pulley...
you might want to read this :
http://www.zerotohundred.com/newforums/toyota/370116-vvt-pulley.html
hi there....need a little help here
my idle speed goes variable...what can i do to fix it??? any sifus hav
any idea???? i appreciate ur advise..^^
my ride is hyundai coupe 1.8L year 97.....
