- Joined
- Sep 17, 2008
- Messages
- 20,685
- Points
- 1,713
Altis reach 500HP I enough xD
no sir, u wont..i got 300WHP, i'll stop
it certainly doesnt harm anything, but id rather tune it up first and get a baseline on what to do from there onwards. u wont know what u need until uve maximize the capability of any system, until then u wont know if u NEED the methanol kit. if it comes with a fuel controller, then by all means sir..Stock 1zz-fe
not necessarily true sirhahaha..
beside tunin the fuel curve..
it wil save fuel by the cold air it produce..
if im correct..?
it doesnt justify the needs, if u run dis kit with std fueling curve, i dont see how it will help u save fuel. the methanol helps in providing more power, but its gonna be optimize if its not tuned properly
yes sir, because the sensors may or may not be able to detect methanol as fuel. so i strongly believe a wide band tune is necessary for u to fully utilise the methanol kit, dat kit is used in highly modified machines to allow a more aggressive tuning, to improve and gain more powwah(overdoing it for a bit there, lol) sir. u dont need to tune it up to the max pun, just to a point dat u need dis kit to maintain dat tune state safely. iam not saying its not profitable, but adding sumthing dat u cant optimize is not my cuppa tea, especially if they are on the expensive side.So, you are saying that best, I tune the ECU 1st then only proceed for the methanol?
with the methanol kit, sum of the petrol is subbed with methanol allowing for leaner afr (air to fuel as in petrol mixture), hence u rnt using as much fuel, making it seems like fc is improved.Ya, more power = more fc usually..
I just can wishing u good luck in get a good tuner & all the best...:proud:good guys..
thanks alot..
i really learn lots of info for u all..
more info is stil needed.
thanks to the followin..
xtremeleo
Supra_Fanatics
JINEIL2EN
kanan..
---------- Post added at 01:35 PM ---------- 6 hour anti-bump limit - Previous post was at 01:30 PM ----------
ya guys..
my plan is to use the kit plus retune my emanage..
soo just wish me luck..
Similar threads | |
