Newbienissan
Banned
khoyos,
is there any 4pots might fit 15" offset rims ?
thanks mkmd,
nice/thick wallet is not the question, may refer on the first post, the topic's agenda. there are plenty of 4pots lying in halfcut shops which is ranging 600-800 which is not expensive as new ones, and with the help of machineshop everything is possible. im researching between 2pot and 4pot braking respond. so far alot 2pot users. now like to hear some 4pot users' experience especially track n downhill/rally drivers. appreciate if any 4pot users can share the maximum braking effiency like from 80kmh to 20kmh in a very late braking way, and how much distance needed to slow down..hit a corner, the out of it (more techically experience sharing)
if the context is proton, i think twinpot + pmu rotors + pmu pads + evo twin layer servo will be more than sufficient already. fade resistant, excellent pedal feel, not too heavy sprung weight.
this setup will be a bit expensive due to the pads n rotors. but guaranteed to give u braking confidence in whatever driving conditions, be it on trackdays, winding roads, open highways etc...
yeah nissan r32gtst 4pot can fit in 15inch rims. its the same as the previous "brembo" pic posted earlier... if i'm not mistaken. FC3S 4pot can also fit 15inch rims...
aturo, me thinks the rim is too big for the rotor to brake in time for performance driving. normal street use, emergency brake also might face either brake fade or sudden lock. hmm hmm
wah...sa70 tuh...
but from my opinion ah. if those brembos are original, will costs a bomb rite? at least rm4k....
but y u using taiwan sa70's? he could afford ori ones....
to me it looks like fake...i might be wrong....
to get the truth, u need to ask him bro...
---------- Post added at 03:16 PM ---------- 6 hour anti-bump limit - Previous post was at 03:15 PM ----------
if its real it could be twin pots...cos that rim cant clear 4 pots
those are definitely not brembos. the SUMITOMO logo clearly written there. those are nissan r32 gtst (RB20DET) 4pot brakes hahaha...
lets guess,
Merz E-Class wit AMG 4 pots front & 2 pots rear, while BMW 5 Series wit single pot front & rear...
which 1 do u guys think will given more bite & more shorter distance when braking from 100kph-20kph...???
massive,
your sharing is most valueable bro, thanks ! but according to your setup 4pot front n single pot rear, do you experience and understeer during hardbraking from 80kmh - 40kmh (especially hairpins) ? and can share what size of rims/tyre using ? if 16" would be perfect, 15" will much better for hillclimb/rally/autoX.
i see, thanx. cud it be a faulty 4pot tat time when it jam ?
allright, so rectified that 4pot front, single pot rear wont cause understeer during hard braking entering corner...hmmm. anyway, can u remember how much was the nissan 4pot's brakepads cost ? thnx
can't recall. Used it during trackdays & genting. Not bad. Also considering the car was light
what car are u driving bro?Yes, the mechanism inside jammed. That time no repair kit like evo 2piston has. Im not sure if the caliper is from a nissan skyline or nissan sylvia, but its a nissan 4 piston caliper.
the most important is the braking consistancy respond, and the limit of 4pot in resisting brake fade.
:sleep:
