owners club kancil..
Wah Chai
198
guys,my foremen told me after they bought l2s halfcut from halfcut shop,install and i use 1st.after 1 month only can get the AP document .is it normally like that ?
june5095
4
how u gonna oversize to 1.0 block ??? if u use the crank from kelisa and L2 conrods will be too long and ur piston with pop out of the block ...
my setup last time L2 head with kelisa block and 2E turbo piston .. boostin at 2.5 bar ... 2++whp ... i think the block tahan laa ...:rofl: i shift at 8k rpm cause powerband drops at 8.5k ... not only me la using that block ... so many nowadays L2 using kelisa block ... :wavey:
erm .. then if using kelisa block , can use back l2s gearbox or need to use kelisa gear box ?
SYeNi69
402
47
TTDI KL
yup can use L2 or any kancil gearbox ... if u want to use kelisa also can but must custom driveshaft :biggrin:
Wah Chai
198
somebody please help to answer my question
Qft
5
kuantan
hi guys, my kancil using L5 turbo engne.. but i stiL feel tht my frenz L2s is more pwrful then mine.. how can i mke it more.. eemmmmh!! btw, im using EF-RL model.. im new here..
zeus83
981
55
KL-Damansara
hi guys anyone wanna sell their stock 850 engine??
l200turbo
88
buy things with jdm is ok la..buying halfcut there is a no...they will keep delaying ur custom form...an experienced from my friend who swap njin there....
zul_klasik
83
6
1,508
hai all
ermm
any1 out there have a xprience with kancil loco style theme or JDM style theme??
i'm newbies here
hope u can share knowledge with me
hehehe :wavey:
jj.v6
332
13
johor baru
to all kancil owner..i just lost my rear spoiler mira moderno..those thief they know exactly how to take out.damn........so if u using any mira moderno parts pls be careful...any idea whr can find?my supplier in jb is out of stock...might take 1 month for new stock...thanx
Mar 24, 2010
i just bought 2nd kancil 850 round headlight year 2004...
but i have this problem my temperature can easily go up if i stuck at traffic jam.... more than half the temperature meter... all kancil kancil owner please advice ...
mag9556
2,770
43
1,648
check ur radiator.. maybe stuck.. then check the water pump.. hose... thermostat...
2nd car.. normal d...
good luck...
kAzZa
17
1,503
Sabah
i have kancil 850, converted into l2 engine, anybody know will this endorse? or shud i change back to 850?
and the other thing is its lowerd but im still using perodua suspension on it , shud i change to mira ? or buy after market?
mag9556
2,770
43
1,648
Actually u can downgrade tfrom 850 to 660 but u need to get an approval letter from JPJ, ask from runner..
they have the jalan to settle for you or if u want to safe some for more modification.. u can try to go to your nearest JPJ office and ask..
no worries...
suspension better get from outside.. ori one and halfcut one will not last for long...
good luck..:nurse:
kAzZa
17
1,503
Sabah
hey i have another question,
im currently using l2, the aircon compressor is almost useless, so thinking to fit a new kancil compressor (sanden) anybody know what i require? and how much the compressor cost
Jun 14, 2010
Hi there,
I just bought a 2ND hand kancil and hopping to modifies some of the body panel to Mira spec. So can i find out for your all Kancil lover how much it will cost for the front & back Mira L2s (I think) bumper. And the front & back bonnet too.
Thank Guy.
zul_klasik
83
6
1,508
Hi there,
Thank Guy.
helo bro
check ur inbox
hehehe
As per title , i just change my stock toyota brake system (2pot 1pot ) into aftermarket Brembo (4pot 2pot)(recondition brake calipers) along with new Brembo rotors n Brembo brake pads (400cc). the problem i'm encountering it's the brake squeal whenever on a low speed nearby to stop...(mostly about to reach a traffic light)..the sound came in on n off...is it normal for a brembo brake to squeal? car driven from KL ---> JB ....JB ----> KL after change brake kits..clock more than 500km for...
