WTA - Water Inlet Hose
WrX7
Hi,
Anyone knows the size (dimension) ID,OD and length of the Water Inlet Hose connected between the water pump toward the block. See attached.
Thanks
y u need tat? kong changed once for me...mayb can check wif him...
Planned to change it to silicon as well, searching for correct sizing.
I think u can loosen it a bit to measure the inner diameter by measuring the inlet part (that thing u attach the hose to).
WrX7 - give me a call on Saturday...I'll be at the mech shop...can check for you then...do remind me...:biggrin:
Bro Chin, this saturday not free lar. Maybe i be doin the measurement tomorrow.
Thanks.
Tried fitted the hose on one of the hose outlet on the engine, the measurement of ID:30mm, OD:40mm on the silicon hose should be sufficient. An estimate of 3inches length would be good enough as i couldn't measure it.
Chin, think u can help on this?
Hi WrX7...
I've measure it last saturday...sorry forgot to update you the soonest...
the length was 2.5inch...
