Garmin Mobile XT In Your Car
Thanks K_Takuya, I've tried uninstall, remove everything and install again, it's still the same.
bro,
the SW.UNL file , you created and pasted in the folder before launching the program or after?
the other day when i was installing for my friend...i pasted the unl file...before launching the program on phone after installation and it couldnt work as well...when open program keeps saying trial....
but i uninstall and deleted everything....install back...launch the programme 1st....then close application....connect phone back to pc...paste unl file...then launch garmin again it worked....you might wanna try it and see if it does it for you...
Cheers bro. You are as reliable as my old Fiat, always there when you needed it the most and get me to where I wanted to go. I have got Garmin worked on my new WM6.1 (Samsung Valencia >) and will continue to use it to explore my host country, Indonesia. Thanks all over again!!
No problem bro,just helping each other..cheerss..:beer:
thanks AD_EG, I've solved the problem. I'm so silly to have forgotten deleting the .txt from SW.unl.txt , now it works perfectly fine. Thanks angrysnail !
sorry guys..im newbie here..how to update a map? huhu..my phone already installed with gmxt map version 2.15:confused::confused::banghead::smokin:
don't get confused bro,where u got ur map last time?..this maps is bring by mfm members,is kind of work in any garmin xt..if u have purchased the ori garmin+ori maps i scared ur map function after installing this map will be disappear..if u wanna try,just make a backup for ur 2.15 map and then install this map..:pcguru:
anyone if think have another way to make up this,pls share ur opinion..:hello:
it's was malsing map...mmm..
connect ur phone to pc and look for garmin folder..i am not sure about malsingmap but try look for file with extension xxxx.img..delete it and download new map from malfreemaps,install in ur pc,copy gmapsupp.img to your garmin folder in ur phone..:wavey:
it's mean everytime we need to update a map..delete previous map first rite?...thanks bro..
snail, i put da radar scanner in my phone edi but why it doesnt detect any ah??
radar scanner? wah thats cool bro...like a speed detector scanner or what ?
any bro try 2 use this software in sg?on last fri i drove 2 sg, when clear the custom at woodlands immediately it sounded 'lost satellites reception' and after tat it remains like tat till i go out from sg.....when clear tuas checkpoint it come bak alive haha....
i already install the updated map....any bro encounter this problem b4??it seems that it could not detect any satellites in sg....
eh bro share la the details?
whats the programme/software called? where to downloadn?
Write your reply...
