4g67 turbo..
hi sifus...
i hv 4g67 n i plan to bot it since i hv enough item such turbo,evo gb,evo tb n few more..so i want to rebore 67 block tu 85mm evo piston n put oil squitter...but can i use back 4g67 head?since we already know 4g67 head combusition chamber 43cc n evo 47cc?hv any problem if using 4g67 head back like to high compression,knocking,detonation or what ever can caused a big problem..
hi sifus...
If u use EVO 3 pistons, U gonna get CR > 9. If u gonna use EVO 1/2 pistons, Ur case is 8.5<CR<9. Having high engine CR turbocharged is fun, but U'll never be able to boost high + u need to retard even more of ignition timing when full boost.
Tunning is a must. Also remember increasing the engine capacity will require a bigger capacity injectors.
Using EVO TB, if u are using 4G67 intake manifold, spend some bucks boring up the inlet of the manifold to 60mm. Else, it'll restrict the Airflow into the manifold.
owh i already hv fpr,evo 510cc injector,walbro fp,emanage from my previous engine 4g93t....so if i use evo 1,2 piston with head 4g67+1.5mm metal gasket it is safe to boosting until 1.5bar or little more?
how about vr4 4g63 turbo piston?
Haha... can't guaranty that. Boosting 1.5bars on EVOs with 510cc injectors is just on the border line. But, 4G67 head + block + EVO 1/2 pistons is good and nice to play with. If u plunk in the 1.5mm gasket, u'll defeat the puspose of using the 67 head. might as well use the EVO's head. At least the cams are more suitable and doesn;t encounter valve overlapping problem.
Make it more clear for you.
Boost figure is just an indicative value of the pressure u are inducing into the manifold/engine. A VR4 block boosting at 1.5 bars is only equivalent to EVO 3 boosting at 1.1bar due to the super low CR of 7.8 if I'm not mistaken. And have such CR, not nice to drive at low RPM without boost. To me, i might as well having a little higher CR and boost at a lower pressure.
At least u get a balance between a the low and top end power.
hurmmm.. vr4 boosting 1.5 = evo boosting 1.1.. Now I boost 1.3 in evo, so in vr4 like boosting 1.7?
so much different? like this wanna put evo piston to vr4 block la..
how much machine shop take to put evo piston to vr4 conrods? anyone know?
my purpose to using 67 head bcoz to save budget lar.. but as u said if im using 1.5mm metal gasket will make my engine have more safety n decrease the compression rite?i just worried about knocking n detonation between head n piston... n of course after finish running i will go tune to make sure enough fuel supply to my cylinder...
Lets have a basic comparison on the CR between these 3 engines
4G63T EVO 1/2 = 8.5:1
4G63T EVO 3 = 9.0:1
4G63T VR 4 = 7.8 : 1
What I was trying to say is, VR4 need to boost 1.5 bars in order to achieve the equivalent power output of EVO 3 boosting at only 1.1 bar. Meaning to say EVO's Power/pressure induction is much more efficient. So, if u plunk in VR4 pistons, CR = 7.8. Not nice to drive. Esspecially driving slow + laggy.
But if u wanna use VR4 conrod in EVO block, u require some modification. On the piston side, if the pins are 19mm, u just need to pump them out and reinstal. no modification needed if i'm not mistaken.
---------- Post added at 12:45 PM ---------- Previous post was at 12:43 PM ----------
if u are using EVO ECU, u're safe from knocking with EVO 1/2 pistons. Very slightly rich. U may not even realize while driving. U'll realize when u refill ur empty and and the moment before u reset the mileage. U'll be like, eh...? apsal KM dah kureng..?
4G63T EVO 3 = 9.0:1
Now i use evo blok but I have spare vr4 blok waiting for rebuild.. What I mean, I want to put evo piston in vr4 blok.. from what I read, need to do some machining work to fit evo piston to vr4 rod because vr4 pin is bigger, 21/22mm if not mistaken..
I get what u're saying just a bit curious to know that there are so much different between vr4 and evo interm of power both make and its all because of CR. Because I'm planning to max out tdo5 to 1.6 bar in vr4 bottom, If the power is same with evo boosting 1.3 bar, no point I rebuild vr4 because I have achieve that :confused: if there any differents if I use Standalone to tune that vr4? I mean to achieve same hp at same boost level as evo?
Well, of course. Plunk in an EVO engine on a VR4 ECU set up without any management. Boost it at 1.2 bars. Kapiang....!!!! Engine letup!!! We are talking about 7.8:1 vs 9:1(EVO 3) The power difference doesn't only comes from the CR, it also comes from the more aggressive ignition and A/F mapping of an EVO.
Well, back to ur set up. the stroke and bore of VR4 and EVO are the same. Not too sure about the volume of the cylinder head. But the CR rating of the VR4 is definitely different between VR4/EVO 1-2/EVO 3. Assuming u are using EVO's head. When u plunk in EVO pistons, U'll get CR of an EVO. So, u'll get a stronger rods EVO. Worth the effort.
But do note that EVO's flywheel cannot be mounted on a VR4 crank. BTW, have u settle ur engine misalignment problem..?
Yeah I know the differents CR between them, just shock to know there will be much differents in power output with same level of boost but I assume u say this if both vr4 and evo all in stock, right?
Differents between vr4 and evo are piston CR.. another one is vr4 rod thicker than evo thus can hold much boost than thinner evo conrods. I think the best is put evo piston into vr4 blok. if put vr4 rod into evo blok have to do a lot machining, first to fit with evo conrods and then evo piston.
Crankwalk maybe another issues with evo blok, I know its debatable but I have experience it :banghead:
BTW, I have totaled out my 510cc injector duty cycled (100%) by 1.3bar in evo blok and tdo5 :stupid: I guess I should be running low 300++ hp if calculate by injector duty cycled. Hope to increase to 1.6bar when my new injector arrive but afraid evo blok cannot handled it, thats why want to rebuilt vr4 blok. but when u say 1.5bar vr4 same with 1.1bar evo, make me wonder what I should do next:banghead: but standalone for sure will be coming next :biggrin:
BTW about the misaligned engined, its true.. My oil leaking stop after that, now just a bit only that I can live with it..
When u install EVO pistons into VR4 complete block. it'll behave like EVO performance and durability of a VR4(refering to conrods) if u are also using EVO head.
Standalones would be nice... Don;t worry lar brudder... Need anymore clarification, don;t hessitate to call me...
hi paranoid_android ....
if your evo block still in good condition.... no need lah replace it with vr4.... evo block can handle.. no prob... why you wanna push yr turbo to the limit?? no good lah...
better put yr money upgrade yr td05 to 20g or find new good turbo... bullseye maybe...
standalone no need lah for minor upgrade..... just emanage blue + ignition harness ok already..
ensure enough fuel & proper tune ...
hurmm, maybe I will do that, put evo piston in vr4 blok and I will be using evo head. Just dont know how much machine shop will charged to fit that evo piston into vr4 rod :smokin: u have evo piston lying down? :biggrin: I assume evo lsd gearbox at Alvin workshop is yours? I'm buying it from mell but have no time to pick it up yet..
---------- Post added at 04:37 PM ---------- Previous post was at 04:24 PM ----------
I'm just afraid evo block cannot stand 1.6bar of tdo5.. from what I read, evo can stand until 1.3bar only.. U got experience evo block 400hp bro? hope u can share..
no budget for new turbo bro and I just want to keep my engine below 400hp.. as for standalone, for me its a good investment for future upgrade plus I can extract few more potential of tdo5..I already using e-manage blue..
ok... you need to learn how to read compressor map first....
from my rough calculation....
VE = 100%
Pr = 2.6
L = 2.0
rpm = 8000
after calculation... using 2.0 engine, boost 1.6bar @ 8000rpm .... you engine flow = 735CFM
plot 735CFM @ 2.6 Pr ...... TD05 16g will choke already ..... so you cannot boost 1.6bar with td05... yr turbo & engine will kebaboommm....
The sifu has spoken...
However, According to people whom used TD05 with 20g fin also some lesson from Tong turbo, 20g is way oversized for what the housing is capable of delivering. Performance range is within 1.2 bar. Anything higher will choke the housing.
Normally it's the pistons that fails. not the block brudder. BTW, a front wheel drive >350WHP is not easy to handle. If u have LSD, things are better. But still, it's not something fun to drive except for straight road.
Bro nan83, if I'm not mistaken, panaroid_android is using TD05 16g from EVO 3 with bigger compressor wheel.
thanks nan83 for the links.. i have calculate and maximum boost i can achieve is [email protected] at 6500rpm.. FYI, I shift at 6.5k rpm so meaning I still can boost 1.5bar in my conditioned..
Btw, thanks a lot bro nan83 :biggrin:
now I know how to calculate it
---------- Post added at 08:25 PM ---------- Previous post was at 08:20 PM ----------
actually not the piston but rods usually failed in evo blok..
>350hp ok with me as I drive at straight road only :biggrin:
I only drag, no corner2 :driver:
yaaa... you can do that... but remember you working at critical .... maybe turbo rotate around 130000-150000rpm , turbo not efficient & air intake temperature high ..... turbo kong faster..
you need a good intercooler to cool the air intake.. hot air kill engine too ..
that why i tell to upgrade turbine.... big turbine will operate efficiently .. low air intake temp, low turbine rotate .... = long life turbo & long life engine...
that mean - 350hp with td05 = not safe... (stock engine)
- 350hp with bigger turbine = safe (stock also)
that why a lots ppl say turbo engine manja..... coz they dunno how to upgrade... just wanna up boost only...
forge piston also cannot like that....
another exp:
yr target 400hp...
- use gt28rs & push it to da max + forge piston (use pump gas)
- use gt3076r just boosting at 1.5bar + stock piston (use pump gas)
both can get 400hp... i believe gt28rs +forge piston will kong faster ...
the gt3076r with just stock piston will survive & no big prob..
______________________________________
with good setup & tuning... evo block can tahan 400hp++ .... but dun abuse it lah...
another exp:
yr target 400hp...
thanks a lot for ur advised bro, really appreciate it.. for now tdo5 will do until I get enough money for s256 (my dream turbo) :driver:
A thread every 60 seconds
