biz-da-tech
520
how long should do the cleaning?
which should do cleaning also.
but dam alot of people said is normal around 280km to 320km
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
If I do all that, how much will I expect for improvement?. BTW, car is almost 11 years old. Final say, engine damn tough!
i dunno how to calculate leh
JeN1707
55
dear sifus....
i got a small question here which i'm abit puzzled here..
what's the difference between Port n Polish, and Top OverHaul ??
Its the same thing izzit ??
tofu_manic
1,342
91
5,148
top overhaul is just a regular maintenance procedure, replacing wear/tear items
port/polish is the process of improving the flow through the engine head, via porting/polishing the intake/exhaust parts of the engine head
eh guan post edi hehe listen to him, diy master
chris_ch3w
407
4
if free, u can open up urself the head and do ur self port n polish...the tools can be bought from homeDIY or any hardware shop, the tools cost around rm3-400...now u save ur rm900-rm400(cost of tools)=rm500 + countless and timeless effort :rofl:
afmarsyal
100
6
I did mine at 20 intake, 15 exhaust, cold engine. Moderate FC, not too noisy, not too powerfull either. Camshaft is not standard lah..
thanx sifoo, i knew something is wrong with my current setup..should be smaller at the exhaust..did my 20 intake 20 exhaust during engine mildly hot..will look into it..another problem is my engine quite slow revving..my tb is 4g92p, injector 210cc..however spark plug is mint condition..no trace of too rich, or too lean after i plat with my tps and ditributor..why is it my engine feel a bit 'sebu'? do i have to advance the distributor a bit..i like how my throttle response now..my car feel light to accelerate..only on hard and sudden acceleration, this 'sebu' and slow revving symptom occurs..thank you in advance
joev8796
145
guan... just realised tat spare part shops sellin SE spring... i asked him y din tel me tat whn i told him da 1.6 spring is 4 my 4G15... wanna die liao
tofu_manic
1,342
91
5,148
wah fren PnP is not something to diy
u cud mess up the head and have to buy a new one
or the car wont reap the benefits of a proper PnP head
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
diy polish can la...port...err... if abit ok la... but if really wan do, better ask pro do... agak2 like dat better dun do... haha...
langsuyrx
331
43
3,028
Kay L
facebook.com
dear all sifoo... my 4g15 oredi producing white smoke lar.. sometime little smoke, sometime like a fogging machine... what type of valve seal i should get (a very quality and tahan one)..tq
khguan
4,818
26
Seri Kembangan
fotopic.net
for ur case u need to change the piston rings liao... oil seals alone not enough...
---------- Post added at 09:49 PM ---------- Previous post was at 09:46 PM ----------
hahaha... so now how?? when u have budget then only buy lo...
afmarsyal
100
6
i change mine at eon service..cost me rm180..but under the tree pomen would recommend original mitsubishi valve seal..cost around rm200 installation excluded..but i think at least go for proton..i did engine overhaul once, change the valve seal to bad quality ones..i think around rm80 a set and end up regretting it..only two month using then bocor oredi..and due to the act of stupidity i made, i end up ignoring it for two years, continue to top up the engine oil every 2000km - 3000km until recently when i had to top the engine oil every 1500km..only then i decided enough is enough..no la, only recently got money to change the valve seal.. :P
p/s : i advance the distributor a bit and reduced my problem..anybody got better solution for my problem?
hi everyone in zth i'm recently install this engine 6A12 TT in my perdana, and now its completely standard and original, just need so info on how to upgrade this mac ? wat should i do first? any sifu or expert can help me ? thank you very much.
