Oil starvation
adian
395
57
3,028
www.the-yeins.com
Fellas...
I did the UluYam-Batang Kali-Genting run last weekend, first time I'm doing it in my Tezza. And I noticed something alarming: I drift all the corners towards the top bouncing on the limiter in 2nd gear (mine's a 5AT), and when I check the oil pressure gauge as I do so, it drops down to 1/4.
Backing off, I stopped drifting and instead just whacked the corners in grip mode, the assumption being that perhaps the sideways action plus high-rpm could be causing it. But it doesn't change anything, oil pressure still drops. Onthe straights, it comes back up.
This means that the 3S-GE is suffering oil starvation on high-G cornering loads! I find this incredible. This only really happens with old tech engines, and by and large is eradicated from modern Japanese engines from the 90s onwards.
I suppose this is exacerbated by the fact that our BEAMS engine requires a lot of oil volume and pressure to run the VVTi at full chat. But still, I'm quite incredulous.
So my question is, do you guys suffer the same thing?? Don't tell me I'm going to have to baffle my sump just to enjoy Sunday drives and track days. Any feedback on this is appreciated.
/adian
cuscostrutbrace
987
62
3,028
Hmm,i never see the oil press gauge while cornering,maybe i should look at it after this..and agreed it does need a good oil press to keep the VVTi running,as most engine with cam phasing/cam changing technology.
Bump: Hmm,i never see the oil press gauge while cornering,maybe i should look at it after this..and agreed it does need a good oil press to keep the VVTi running,as most engine with cam phasing/cam changing technology.
cuscostrutbrace
987
62
3,028
Watched the oil press gauge during some fast cornering left and right,it doesnt seem to drop at all.
koolspyda
2,889
55
5,148
KayEl
koolspyda.blogspot.com
Fellas...
/adian
sure your 'sunday drive' is like ordinary people's sunday drive adian ? :biggrin:
circumstantial :biggrin:
not certain on 3SGE engine, the 2zz in occasions has a trouble spot with oil pump gear.
(for no reason we dont know why the stock 2zz sump isnt baffled. 1zz is)
A Post Every 5 Mins
Guys, anyone tried doing a light dimmer in your cabin? Like those BMW when the door closed, the cabin light will only goes off after a few seconds. I have tried the following circuit. Having problem... Yes, the circuit works, but the light only gets dimmer, really just dimmer and doesnt go off. Can someone share how to improve on the circuit or if a better circuit to share? Thank u.
[FONT=Times New...
