to all otai out there pleze give so info...
isit posible to spool up t67 turbo on mivec 1.8 turbo spec engine:hmmmm:
i think the question is too ambigious and the most obvious answer to this = YES
any engine will spool any turbo.. it's only a matter of how and when..
and as Jin said..T67 has many variants..and there's also CHINA made T67-wannabe..
and T67 has many turbine housing variants as well, you've got 10cm2, 12cm2, 14cm2 and so on a so forth..
What about the hardware in your car..your engine...your tuner...your fuel to use (Ron 95? Ron 97? VP16 ? C16? or ??)
try to narrow the questions... it'll be easier for forumners to help you out..
turbo are greedy t67 wif 12cm2 .
engine specs
std size supercaz piston wif b8 210 c/rod
haltech e6x
curently running wif ron 97
dont buy first and ask questions later. u will suffer if the turbo doesnt match the engine. always ask ur engine builder, tuner and turbo sifu to give feedback on which turbo suits ur setup n ur goals, then only choose among their recommendations.i now conflict of choosing turbo...hehehhe pening siut![]()
).....Its...
