khguan
4,818
26
Seri Kembangan
fotopic.net
drex is using super4 plugs.... been using for damn long already... i think at least 4 years already... still running in his car...
my engine is using NGK small head plugs... BKR6E if not mistaken... more power n nicer to rev on my stocknia settings...
khguan
4,818
26
Seri Kembangan
fotopic.net
i got a set of Splitfire Triple Platinum... my fren gave them to me when he was selling off his car... he claimed that one set is RM2XX...
well... the torque is better... but i use a cheap of cheap no 6 plugs also get the same results..:confused:
ettm_14
605
81
saw one guy selling apexi AFC Single Button for Rm280, actually worth it or not?can it help tune my Air fuel ratio?seems like it comes with the harness
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
guan, i tried using the small head plug before, but modded arr.... lasted me a few weeks only dont know why... mayb fouled by overly rich AFR... engine sputtered and mis fired... at last i remove it and replace with normal big head type...
why having a resistored sparkplug is better in fuel injection engine??..
isn't it the heat range that matters, not the plug type?
yeap... but of coz, the model also important... size does matter...
not worth... if can get safcII... price now soar up to rm800 for 2nd hand item... crazy... but safcII offers 12-point fuel correction instead of 1-point fuel correction in AFC single button....
top up abit more get SAFC neo, 16-point fuel correction... with vr nice GUI display... :P
labulabi
78
from my experience, different engine setup needs different plugs. i've used various spark plugs, incl iridium, super 4, g power, champion copper cold, and now cheapo waja plug..every one of them is useful, just a matter of which spark plug supply the most suitable heat range that our engine setup required.the thing about iridium is, they last longer but not necessarily being the most suitable.
im a newbie. dont whack me if im wrong:driver:
fstr
7,935
954
Sahara Desert
all this while i am using cheap plugs or shud i say 17 bucks normal denso plugs.. bought da super 4 cos of gra so needed some oomphh while going out of a cone :rofl:
anyway da super 4 cost 45 bucks only, worth da try :driver:
biz-da-tech
520
Splitfire I get around rm140rm so might going to try out since guan said rm2xx expensive :p
Well I forget what iridium I using all I know the poster of the cover is eagle? Do any one know what brand is that?
Thx for the video
Bump: Splitfire I get around rm140rm so might going to try out since guan said rm2xx expensive :p
Thx for the video
Mar 21, 2008
674
15
good sharing :)
according to my experience :
- Bosch super4 have not much difference than stock plugs, performance un-noticable
- Iridium is useless piece of shit and overpriced
(copper is much responsive to produce sparks)
- Volker is slightly better but overpriced
- Spitfire is good, with stock plug cables, you can feel the respond at the low rev is much better
The best setup I using now, is.......NGK oem plugs ! With DIY Side-Gapping, along with Pro-Rallye power plug cables. Pro-Rallye costs about RM180-220 and worth every single cent, it improved my engine revving powerband TREMEDOUSLY!
I believe, possessing a MSD spark coil amplifier, is the best (RM1300+-) kekeke
my 1cent :wavey:
biz-da-tech
520
but some said the improvement u can't really feel and all also is same just only u can see the different is lifespan???
Well LOL plug cable do the most of the thing?
Pro tallye cable are good right? Currenttly using redline 10mm.
Bump: but some said the improvement u can't really feel and all also is same just only u can see the different is lifespan???
ettm_14
605
81
using bosch sports cable+with bosch iridium platinum fuse= lower pick up and higher FC....lols
Mar 21, 2008
674
15
Pro tallye cable are good right? Currently using redline 10mm.
How's the Redline cables doing ? I havent tried before, hmmmm
Pro-Rallye cables have a capasistor on each individual cable to each spark plug, thats the magic of it :)
The Marketplace Top Posts
I am a newbie in this car world so need a little help please..Recently i changed to a sport spring..After changing it i noticed the gap of my front tyres are different, one is lower, one is higher..Why does this happen ek..
