DIY -Retoration of head lamps like new !
loose_end
3,649
197
Malaysia
Marvelous..So , what substances that actually stick to the plastic headlamp??...Thank You Very Much:adore::adore:
wch5274
13
walau wehhhh....
thats 2 nice...... :proud:
good idea.... using sand paper mean we r throwing some layer of glass??? r we??
can it be done to waja.... quite jealouse with u lah :adore:
UltimateShine
66
13
1,508
www.ultimateshine.com.my
You may use Car Compound for heavy swirls, dull and yellowish lamps.
or
Car Polishing cream for mid to mild swirls and not so heavy hazy lamps
and
a layer of glaze or best still with plastic sealant to seal off the plastic panel so that your head lamps is protecting against Ultra Violet Ray (UV Ray) and minimise the scratches.
Merry Christmas !
best wishes from
loose_end
3,649
197
Malaysia
or
and
Merry Christmas !
best wishes from
Erm , i mean the layer that makes it dull..sorry
Bump:
i tried using brasso on my headlamps.. it doesn't work.. i didn't sand it 1st tho
Wah , where you get this idea from..i thought brasso is only to shine metals ?..
UltimateShine
66
13
1,508
Restoration can be done on any polycarbonate(hard and flexi plastic) head lamp which i believe your Waja lamps are also the same material.
How to identify if it is polycarbonate ? :listen: just knock with your finger and you'll hear the hard plastic sound, otherwise its made of glass :biggrin:
Most car manufacturer using polycarbonate plastic for head lamps since 1995 for cost saving, better clarity and not easily breakable(coz polycarbonate is a kind of very hard but flexi plastic)
the professional radio control car body like kyosho are mostly made of Polycarbonate !:driver:
Bump:
I am not sure if brasso is petroluem based, if yes then it make more harm then good to your lamps as it will melt your plastic to a certain extent, just polish with compound (for heavy swirl) or polishing cream will do. :itsme:
xand
410
13
www.facebook.com
1) Wash headlamp with soapy water then dry.
2) Put masking tape to cover the headlamp surrounding to avoid scratches to those areas.
3) Apply Polishing Compound or Polishing Cream to the headlamp, then polish with 1,500 grit sand paper.
4) Repeat apply polishing compound/cream while polishing with sand paper, and final with 2,500 girt sand paper.
5) Wipe and buff off the polished residue with a piece of clean microfiber cloth.
Are the steps correct, especially Step 3 and Step 4?
Guess the polishing compound/cream act as a 'lubricant' for the sand paper for polishing, right? If not, sure the sand paper will damage the headlamp's surface...
UltimateShine
66
13
1,508
1) Are the steps correct, especially Step 3 and Step 4?
:listen:
3) sand with 1,500 and final with 2,500 girt sand paper to remove swirls, scratches and yellowish layer.
4.) Polish to remove the fine swirls left after 2,500 grit sanding.
5.) final protection with layer(s) of glaze or sealant .
xand
410
13
www.facebook.com
thanks for making it clear.. my kelisa headlamp having same problem too, tout of replacing with new headlamps, but guess i got another option n save my wallet if this works.
epitBDL
232
great diy!just wondering..is it as easy as it look?i'll definitely try on my headlight.was thinking to clear coat after finishing...what r your opinion?better to clearcoat or not...:driver:
UltimateShine
66
13
1,508
I am not sure if clear coat will peal off after sometime on the Plastic lamps and worst still if the spray work is not perfect. ie : orange peel effect which cause the lamp does not focus on the right spots like OEM standard. :hmmmm:
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
i have a same tot as well...
wishleo
2
I wander aftre the process how long will its last before its will dull again... any bros hv experience can advise..?:confused:
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
if i sand the headlights the headlights will have scratches right? won't it do more damage to the headlights? what kind of polishing compound should I use?
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
i think the polishing compound used in this diy is Rubbing Compound.
its like polish cream, but got "microsand" substance. can be feel if u try with ur finger.
its like finest grade sandpaper, but in cream form.
hardware got. just ask for rubbing compound.
it will remove 2500 grade "marks".
if want to make sure, try the steps on other surface 1st.
preferable clear plastic.
the u will get the idea how to polish ur headlamp.. i mean ur car headlamp
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Very very good tips bro. I will have to try them on my old car's headlamps...
Bump: Very very good tips bro. I will have to try them on my old car's headlamps...
babyken
121
9
quite amazing... will try it out myself....
my getzy have very very blur cover~
traize
519
5
how bout glass?
pencalat
805
19
JB
Anyone tried it yet?
Care to share some before and after pics?
Eager to know from ur guys..
UltimateShine
66
13
1,508
The purpose of sanding headlights is to even out the layer (remove scratches) for a mirror, crystal clear finished after compound and polish. :itsme:
we are using Optimum compound in this video clip !
Optimum Compound detail : http://www.ultimateshine.com.my/webshaper/store/viewProd.asp?pkProductItem=23
After compounding, the result is shine like wax, we suggest another layer of sealant to protect from UV ray damages. :biggrin:
need some info ...
I planning to change my GTI's clutch plate , can anyone suggest what is the suitable and smooth clucth plate ? BTW wwhich is the best gear oil ....full sentitic or semi sentitic ?????
Actually , i was planning to change MMC clutch plate but some says it is very hard to press ,,, is it true ???
thks
