VR4 220 to upgrade to +-300 whp
nevermind if my valvecover paint cracked or peeling...what i need is only powerful engine...hahaha:rofl:
turbo kicks at what rpm with this AR 50........if 3k rpm still ok but 4k rpm too late i think.
once again another misconception bro
AR50 is a housing only :D , see the pic below
in other words , it cant range from 200hp up to 500-600hp
wht specs do u wish to buy ? t3 ? t4 turbine housing ?
.48 , .63 housing ?
t310 turbine wheel ?
t350 turbine wheel ?
compressor wheel , 46trim , 50trim , 54trim , 60trim , 60-1 ?
48mm , 52mm , 54mm , 56mm , 59mm ? got sooooooo many types bro
cant tell hw fast it will spool
a AR50 50trim .63 t3 turbine t310 might get fullboost at 4200rpm
a AR50 50trim .48 t3 turbine t310 might get fullboost at 3800rpm
a AR50 50trim .63 t3 turbine t350 might get fullboost at 4500rpm
a AR50 50trim .48 t3 turbine t310 might get fullboost at 3800rpm but it might hurt ur top end power and have a power drop by 6krpm
so , by ar50 , cant really tell anything bro :)
i guess u research abit bout turbo n learn bit , sure very interesting to read n learn , then u can understand wht im trying to say
ur question is similar to , td06 on vr4 how fast spool
ahak , see td06 got td06 20h , td06h 20g , td06sl2 20g , got td06h-25g
then got turbine housing 7cm housing , 8cm housing , 10cm housing , 12cm , etc
huhuhuhu too many factors :D
.48 , .63 housing ?
wow wow wow........too much to choose and need to learn more before purchase. jinkl very informative. thanks again!
yes2..wash him jinkl..until ar issue stick in his head hahaha:rofl::rofl:
pro.....don racun2 and wash too much laaaa.....after forget everything......lol......:rofl::rofl:
adui, not yet sleep or just got up :P
stock vr4 piston and below, which one to choose????????
if too powerful will blow my piston or not???????
no budget yet to change pistons:bawling::bawling:
it's ok with stock vr4 piston...power did not blow the piston but detonation does....so be careful during tuning the engine...anyone else have any opinion?
Im using stock vr4 piston..no problem at all till now...(hopefully....huhuhu)
good machine and good tuning sure last long.......that's what i want but don't exceed budget lahh of course.....:thefinger::thefinger:
Write your reply...
