Viton® valve stem seals
CenturyAutoparts
VITON® VALVE STEM SEALS FOR UR CAR PERFORMANCE WITHOUT WORRYING ABOUT VALVE STEM SEALS DAMAGED BY THE HEAT OF YOUR ENGINE!!!
SOLUTION TO YOUR VALVE STEM SEALS PROBLEM!!!
Viton® is a brand of synthetic rubber and fluoropolymer elastomer commonly used in O-rings and other moulded or extruded goods. The name is a registered trademark of DuPont Performance Elastomers L.L.C..
Viton fluoroelastomers are categorized under the ASTM D1418 & ISO 1629 designation of FKM. This class of elastomers is a family comprising copolymers of hexafluoropropylene (HFP) and vinylidene fluoride (VDF or VF2), terpolymers of tetrafluoroethylene (TFE), vinylidene fluoride (VDF) and hexafluoropropylene (HFP) as well as perfluoromethylvinylether (PMVE) containing specialties.
WHY Viton®???
Fluoroelastomer(FKM and Viton) seals cost roughly 12 times as much as nitrile, but have a temperature range of -5º to 450º F, making them one of the best high-temperature seals available.
Viton has good flexibility like nitrile, which means it can handle some runout between the valve stem and guide. It is also considered to be a more durable material than silicone. Viton also has better wear resistance than most other seal materials, making it a good choice for applications where long term durability is a must.
SO WHY WAIT???
MODEL AVAILABLE
MITSUBISHI
HONDA
TOYOTA
PROTON
MERCEDES
BMW
and ETC...
UPON ORDER, PLS WRITE DOWN YOUR ENGINE MODEL
Eg:
Proton Satria 1.6
4G92P SOHC
However, due to some issue with the registration of the name VITON®, The manufacturer used a different name as an approach to the competitive market. The name of this material from Our manufacturer is called VILTON
*Note:
Delivery will be done 1 day confirmation or order. Any enquiries after 5pm will consider the next day order.
For any enquiries or order, pls e-mail to:
[email protected]
or Call
Kenny
019-3306693
*Got myself another phone. So, continue using this number.
hi , just wanna know do u have metal head gasket for supra 3.0 Na ???
reply me for iswara 4g13p. price include delivery to terengganu
