- Joined
- Apr 6, 2007
- Messages
- 4,966
- Points
- 1,638
emmm i just spend almost 10k to convert my 4g15 to 4g92 mivec
10K..??
Thats quiet expensive.. bro.
Whats the different between 6A10 vs 4G91 vs 4G92?
Maintainance.. performance.. etc
iz, those hp figures are on paper only, claims by manufacturer.
it will be lesser then that when on dyno.
mine 4g91 has only 102 bhp on wheel when its standard, now more then 120 but bear in mind an engine is not at all about horsepower, TORQUE is!!!
oooo... thats really cheap bro....rm10k included 15" sport rim , half cut , tyre, labor, jpj ,spare part bla bla bla
4g92 mivec will be better off at pickup... because 4g92 mivec engine is lighter...by the anyone try 6a10 vs 4g92 mivec?? since their HP almost same.
6a10 = 1.6L v6 engine
10K..??
that depends on how heavy is ur right foot... but of all, i would say 4g91 would fare better off...Bro, how about the FC..? 6A10 vs 4G91(at) vs 4G92..?
through inspection... replace all wear n tear items such as timing belt, water pump, oil pump, bla bla bla... if piston ring gone, need overhaul loh...Bros.. Usually what have to be done before engine from the halfcut been install..? Some says timing belt..![]()
for FC
my friend's 6a10 ( manual) wit full tank from KL to genting then genting back to KL then KL to melaka and melaka to KL used only half tank only
while the 4g92 mivec (auto) rm 10 of fuel for 75 km
thats considered normal drive only. heavy foot style RM60 200km:stupid: cant imagine what will the fc goes when transplant to 1.8 later
bro popout,
why dont you change to manual transmission instead of auto geh? I think would be better on pickup on manual gear box :)
U ask me y ya ....... first my poket is not deep enought if wan manual need addition rm1k plus i always drive in KL u know la the trafic is very "GOOD" one. but i alrealy statify wit the auto performance dy if not i terus taruk 4g93t dy ni need mivec lo
bro popout,
for FC
Kesas no money pay tol la bro i always go in the traffic jam road
every day go usj by using bukit jalil puchong road
last time my friends 6a10 using auto but go up genting 4 times and the gb kong dy so now using manual .
hmmm form the information look like the 1.6 v6 is more powerful compare 1.6 mivec...
Bros, got some info from the internet.. but still need to know more about this rare engine user...
Mitsubishi 6A1x engine
The 6A1x series is a V6 piston engine from Mitsubishi Motors. The 1.6 L 6A10 holds the distinction of being the smallest modern production V6.
6A10
With the engine capacity of only 1.6 L (1597 cc), this is the smallest yet most powerful 1.6 L engine available on production car. With the configuration of 6 cylinders, dual overhead cam (DOHC), and 4 valves per cylinder, the 6A10 engine manages to output 140 hp (104 kW) @ 7000 rpm in stock condition.
Available in the Mitsubishi Lancer MX in 1992, this engine was once the most sought after engine for modification in Japan. In 1994, the Kotsumi's brothers from Kanagawa, Japan, managed to turn the 1.6 litre engine into a 'little monster' able to produce 430 bhp (320 kW) @ 6000 rpm without a forced induction system.
Specifications
Displacement: 1597 cc
Power: 140 PS (103 kW) @ 7000 rpm
Torque: 147 Nm @ 4500 rpm
Power density: 7.71
Engine type: V type 6 cylinder DOHC 24 valve
Fuel system: ECI multiple (electrically controlled gasoline injection)
Fuel type: Unleaded premium gasoline
Compression ratio: 10
Bore: 73 mm
Stroke: 63.6 mm
Fuel consumption at 10-15 modes: 8.3 L/100 km
