ok,lemme start by saying that m gonna overhaul my car.because the piston ring kong edy.
so ive done some google here n there,found that B18C + B16a Pistons will produce much higher compression ratio.
11.6:1 i guess.
ok,now this is the problem,the compression ratio is too high.How to make it less compress?
can i just fit in thicker head gasket?like 0.5/0.45 mm?(is it correct?)
this will produce around 11.1:1
will this work?bcos my budget is really low.n changing the pistons is all i can do right now.
btw,its b18c GSR.
11.6:1 i guess.
btw,its b18c GSR.
