Newbie askin' for opinion...
Mistaken_Identity
2,540
115
Johore Bahru
Hi to all bro' & sis'...I've just sell off my EVO 7 & I'm lookin' forward to buy a GTR 34, which is my dreamt car...What should I look into during my hunt for an unregistered GTR 34 in order for me to enjoy my next ride without any headache..??? Thanks for all the input...:biggrin:
.S K A G E E.
803
I guess when buying a GTR, the things that you'd need to look out for are similar to any other cars that you'd buy. For me to list out everything would be a pain....so besides the normal procedure of inspecting a car before buying (ie;bodywork,engine, interior) .The following are some of the stuff that I would think is unique to look out for when it comes to GTRs
1) Make sure that all the 'check' lights in the meter claster is working; especially the ABS, HICAS and 4WD lights..turn the ignition key before cranking the engine and ALL these indicators and others should light up!! If not, someone has removed the bulb or has tempered with it.. After cranking the engine and you have found that some of the warning lights is on. than you most probably have something wrong with the HICAS or the 4WD system..very rarely these problems could be rectified by just resetting the ecu...so dont accept that excuse from the salesperson that you are buying it from.
2) The standard turbos are extremely fragile...look out for white smoke when start up and on boost and also listen for high pitch sounds when the turbo is winding...these are early indications of the turbo about to go.
3) Crunchy gears..the syncros of the gearbox have the tendency to wear thus causing the grears to crunch when shifting..pay attention to the 3rd and 4th..how ever, this problem sometime only surfaces when the engine is on load..so you'd need to push the car to see if it happens or not..
4) When driving..the steering action should be evenly weighted.. Turning the steering feels the same throughout the steering's turning radius at no time should the steering feel hard suddenly soft ; vice versa..it should feel the same through out..do this at slow speed and at faster speed (80-100km/h)
5) The drive should be steady and stable; You might experience some tramlining especially if the car comes with really wide front and rear tyres..but this should only be experienced when the surface of the road is uneven..if you find the car suddenly darting from on side to another occasionally( even if the sensation is subtle) , its a probable indication of HICAS problems....they might say it an alignment problem but its rarely the case.
I cant think of anyother things besides the obvious ones here...I hope the other members could help with more suggestions
Mistaken_Identity
2,540
115
Johore Bahru
Thanks bro .SKAGEE. for the useful info...Seems like I need to be well equipped with the knowledge before starting my hunt...!!!!:biggrin:
weihan76
129
hey sir skagee,
i think one day we need to sit down with you and document down your knowledge lah. can actually make some money out of doing a book called "How to buy and maintain a Skyline 101" and sell it for USD20bucks or so via online hehehehe.... can do a series actually like the Dummy's Guide.
.S K A G E E.
803
err..if you were to compile everything i know into a book...its gonna be a real thin book with not many pages!!LOLOLOLOLOL..sure kena screwed fro selling it for USD20 bucks
.S K A G E E.
803
Forgot to add
6)Watch the front torque meter..this meter shows how much torque is transfered to the front wheel when the car experiences rear traction loss. The meter should remain static when you are driving along smoothly and only move when u accelerate..any movement while driving normally is an indication of some fault in the 4WD system.
DarkChild
1,449
674
Hello Mistaken Identity,
I also use to drive an Evo 7 and have moved up to getting an GT-R 34. I hope the information that I put up will be of use to you and benefit whoever that is planning to get one.
Cheers
.S K A G E E.,
I would really appreciate it if you stuck this thread up. I'm about to put up a fairly informative post and it would be beneficial to the people who are looking for information next time. Let me write it out first as it's quite long....
DarkChild
1,449
674
There are a lot of things to look out for and I think most enthusiast will give you advice that will walk along the same lines...
Year, Model and Specifications
The most obvious one is the Year and Spec of the car itself. Once you've found yourself a car, it wouldn't hurt to do a little history look-up on the dealer themselves. A lot of dealers these days claim their cars are of later models and of higher spec. I've seen a lot of GTR's who claim to be of 2002 but are not. Claimed to be of V-Spec or V-Spec II or even V-Spec II Nur but are most definitely not. Everyone want's to get what they pay for so be careful and be on the look out.
Usually, you can more or less tell what year the car was manufactured by looking at the sashes of the seatbelts as there would be an indication there. But unfortunately, shoddy car dealers now cut those sashes off as consumers are becoming more aware.
The GTR34 was released in January 1999 in a choice of either standard or V-Spec, and to celebrate the new model's arrival there was also a 300-car limited edition that wore a coat of Midnight Purple II paint. These models had orange front and side turn signals. The cabin had grey interior with red stitching. The center console was gold in color and the back light of A/C display is greenish. The VIN plates located in the engine bay, were usually made in blue in color and the engine bay itself is left black and unpainted. Also note the color of the writing of the fuse box cover is of white in color.
Some of these earlier models also come with a DVD Navigation unit located under the center console air condition vents.
Roughly, V-Spec models has everything of the standard Skyline R34 and came with
Modified active LSD controlled in conjunction by a viscous coupling
Stiffer suspension
Special front and rear Venturi style diffusers (rear is made from carbon)
Attesa E-TS PRO (can redirect up to 50% of the torque to the front wheels within 1/1000th of a second.)
Combination meter with compressed scale below 3.000rpm
Brake air duct
In August 2000, and additional spec was added to the lineup which was the V-Spec II. This brought on a few slight changes made to the cars manufactured. The now later models came in two new colors which is the White Pearl and Sparkling Silver. The N1-spec rear calipers were also used along with clear front and side turn signal/indicators. To differentiate the cabin of the newer models, the interior color had now been changed to black and the centre console has been changed to iridium color with a white-ish backlight. Aluminum sport pedals have been added to the interior as well. The writing on the fuse box cover has been changed to a yellow/orange color. The VIN plates of the later models were now silver in color too if I am not mistaken.
V-Spec II models has everything of the V-Spec models plus a carbon fiber bonnet with NACA duct.
In May 2001, the M-Spec was released. This model was based on the V-Spec II but it was aimed to be a luxury version of the car. It came with softer suspension known as Ripple Control Dampers which reacted more smoothly with the irregularities in the roads. The rear stabilizer was also softened and the front seats came with heaters. It also came with a complete leather interior and Nissan only produced 50 units of M-Spec a month. The M-Spec came in a special paint finish called Champagne Gold.
There was also an extremely rare special N1 spec. According to Nissan’s own records, only 45 were produced over the R34’s five-year model spread. These cars were stripped down specials. There were no air conditioning, rear wash-wiper, rear fog light and in-car audio. The N1 came with a hand built motor from Nissan’s race engine division. This engine used a stronger block, a fully balanced bottom end along with forged pistons, new conrods, oil and water pumps, different exhaust manifold and steel-internal turbos. An even bigger oil cooler was fitted and bigger rear brakes too.
In February 2002, Nissan had announced the final model of the GTR34’s, which were the Nur editions of the V-Spec II and M-Spec. These models both used an N1 engine from the homologation special. The Nur has a 300km/h meter cluster (speedo's). Nissan used the same speedos during the test in Nurburgring. The Nur also comes with a badge on the bumper which is a proper 3D cast badge and not like the stickers on the V-Spec and V-Spec II's. Nur's have a gold colored VIN plate instead of the standard blue or silver VIN plate. The engine cam covers are also covered in gold. The M-Spec edition of the Nur still had leather seats but the seat foam was altered to give a better ride in conjunction with the Ripple Control Dampers. Only 1000 Nur editions were made – 250 M-Specs and 750 V-Spec IIs and they were all sold on the day of release.
In December 2004, NISMO issued a press release of none other than the Z-tune. Only 20 of these will be made and only carefully selected donor cars will be used to make this "finest compilation of the GT-R". This car was trimmed in Alcantara and a redesigned steering wheel. The motor was swapped to a Z2 engine which took the capacity up to 2.8-liters and used components tried and tested in every form of motorsport that the Skyline has raced in. Lot's of work went in to every aspect of the car which I will write in more detail in another post.
Liner
131
Just wondering, i thought the vspecII's came with stiffer suspension and the atessa is even more refined.
russwestwood
543
ofloveandcarbonfibre.blogspot.com
Weihan: Im always picking the Skageeman's brains when it comes to his knowledge and wealth of info, what he's mentioned here is only the tip of the icebearg!
Liner.. dont think so mate, a lot of other stuff, but not those that you mentioned.. :)
Skagee: What is the remedy for a crunchy gears btw..? Besides purchasing a new / aftermarket one, how well can a good mechanic actually overhaul a getrag gearbox?
Mist. Identity: Ive never driven an EVO before, but during your hunt while test driving, do tell us what u think! :)
DarkChild
1,449
674
Engine
Normally, what one should do is check all the fluid levels to make sure they are of the correct level before you start up the motor. Look at how clean the oil and coolant are. Oil should be a light tan color and feel smooth between your fingertips. If it's not, don’t be fooled by the salesman offering you a free service and oil change before you take delivery. The crude needs to be taken out before any more damage is done.
Check the coolant in the expansion reservoir on the driver’s side of the engine bay. Not only should it be spot on the level, but take the cap off and make sure there is no oil floating in the fluid. RB26's have been known to crack their cylinder heads, and the only sign is oil contamination in the coolant. Any sign of contamination is bad news and its best you move on to look for another car.
After looking around the engine bay for any obvious signs of abuse, misuse, lack of care, trails of leaking fluids and so on, go in and turn the ignition key but don't start. Follow .S K A G E E.'s step and go ahead and check if all the check and warning lights light up. As he has mentioned, all the lights should be up and if it is not, someone has tampered with it. If it all lights up, start the engine and it should all go away. If any of them are still lit up, you have a problem. Don't take the salesman's word that it will be fixed after an ECU reset.
Listen to the engine note. It shouldn't have any nasty noises and the motor should be nice and quiet, rustling a bit at idle rather than clanking and knocking. There can be a little tapping from the valve clearances if they haven't been shimmed recently and you can also hear the injectors clicking at idle but nothing too excessive.
Next, check the mileage. At 100 to 120,000km the engine will need to be ‘freshened up’. It will probably need new bottom-end bearings and suchlike. This means that if you’re looking at a car with this sort of mileage and the job hasn’t been done yet, you’re likely to have a large bill in the near possible future. There are plenty of GT-R’s that are running with more kilometers than this but that depends really on how well an owner takes care of his car over the years.
Crankshafts can be a weak point if the motor has been over-revved. Even occasionally letting the engine rev to more than 7800rpm is not healthy but anything below that should be fine. Unfortunately, no one can tell whether an engine has been over-revved until something lets go but if you feel that the motor is very rough at the higher revs, you should look at choosing another car. Straight Six-cylinder motors have perfect primary balance so they should be smooth all around the rev counter. Any coarseness should indicate that the crank is not as straight as it should be.
Turbo’s can also be a problem if it’s the standard ceramic ones particularly if it has had the boost wound up. As .S K A G E E. has mentioned, the stock ceramic turbines are quite fragile. The problem with the ceramic wheels in the stock turbos tend to shear off or fly apart when the boost is wound up above 1.0 bar, which is why most people would rebuild them with steel internals to stop the problem from recurring. Ceramic fins will offer slightly quicker spool time compared to the steel one’s but are more fragile when boost is turned up.
Once the motor is up to temperature, you can check the oil pressure by raising the rev to 4000rpm and checking the oil pressure gauge in the MFD (Multi-Function Display) or just look in the meter cluster in front of your steering wheel underneath the RPM gauge. I can't remember if the stock MFD has the pressure guage, but the Nismo MFD version 2 should have it. It should read 4.0 bar of pressure steadily. Because of the way the gauge is calibrated, you cannot check the pressure with the engine just idling. However, using this 4k rpm at 4 bar rule should prove if the pressure is good enough.
Mistaken_Identity
2,540
115
Johore Bahru
Thanks bro Dark Child for the info...It really help me a lot to understand better about the GTR 34 which is technically I can say it's much complicated than my previous car...
weihan76
129
Russell: Yeah, Datuk Sri Skagee very humble, thin book also can sell USD20 lah. I use bigger fonts k. Im also in the midst of writing a book, but not on cars lah. Its actually pretty exhausting for newbies to find information - as suggested by Dark Child Sifu, i think this thread should be posted up.
Skagee: Boleh lah. USD20 bucks already discounted banyak banyak lah. Can get Janice Yap to promote it during Tripping !! hehehe...
DarkChild
1,449
674
Transmission
Transmission wise, although the transmission can sometimes be a little bit noisy, the six-speed Getrag 'box is quite robust. As .S K A G E E. has mentioned, sometimes the ‘box doesn’t like to be shifted too quickly and will result in the wearing out of the synchros in the higher gears. This applies mainly to the older five-speed 'box of GT-R's (32 and 33), however there is no harm or foul doing a check on the car you're keen on purchasing. Checking how the third, fourth and fifth change feels is a good idea but you have to be travelling at quite a high speed to do this. I wouldn’t recommend speeding but the suggest speeds above 130kph to get a feel for it. If there is gnashing of the teeth, the synchros are not healthy and your gearbox might need rebuilding which would add to your bill. If the change is notchy but otherwise noise-free, it’s often a sign the transmission oil needs changing.
The standard clutch should be smooth in actuation and not slip when the throttle’s opened. It should be very easy to drive, practically no different than any other stock car. If there is any stiffness to the clutch operation or you feel that the revs are rising independently of the road speed, you probably have a burnt or worn out clutch that is slipping. Be aware of any peculiar smells too as you will be able to smell a burnt clutch.
Brakes
The stock Brembo's are generally excellent. While braking, check for signs of any wobbling or shuddering. Look for cracking problems. The discs should be smooth and free of corrosion. Make sure the calipers are looking in good condition and aren’t suffering from any signs of salt damage.
Suspension
A standard GT-R suspension is fairly stiff. It's a good compromise between comfort and handling and should feel nice and tight, abit like your previous Evo. During your test drive, listen for knocks and bangs that could point to worn out bushes or dampers that will need replacing.
DarkChild
1,449
674
The rest are all the usual stops you do in checking a car you're interested in purchasing. Look at the rims and tyres. Check to see the condition of the rims and the wear pattern on the tyres. GT-R’s tend to wear the inside edge of the front tyres because of how the suspension is set up if I’m not mistaken. Check the bodywork for any accident damage or corrosion. Sometimes there will be rust forming around the boot lid brake light. Check the interior for signs of wear. If the gear knob, steering wheel or the clutch-foot area appears to be worn out, it’s a good indication the car has been used a lot and this give you a good reason to be suspicious if the mileage on the car is low.
Mistaken_Identity
2,540
115
Johore Bahru
Hi bros...Yesterday evening I view a used GTR 34 in JB...White colour..Interior & exterior looks okay...All the check light seems functioning okay...But during low idle, there's some noise at the gearbox...This are the info that I copied from the VIN plate...
TYPE: GF BNR 34...
CHASSIS: BNR 34-401310...
MODEL:GGJPRWYR34ZDAAGZAD...
COLOUR TRIM: QX 1G....
ENGINE: RB26(DETT) 2568cc...
TRANS AXLE:FS6R93A RC35...
PLANT M...
The askin' price is RM 265K c/w V-con pro....Any advice for me..???Thanks...
DarkChild
1,449
674
Mistaken Identity,
Maybe russwestwood can do a check for you on the Nissan FAST.
To strengthen my point about the Year, Spec and Model post, have any of you seen the recent Extreme Kars Performance Car Magazine?
It's the August 2007 issue with the MRS with the GULF Le Mans color scheme in the front.
There is a write up on a Nissan Skyline GT-R V-Spec II belonging to one of the guys at Red-Ace Engineering, the company responsible for products and aftermarket parts under the brand SPS or Safety Performance Style.
Can any one tell me what's wrong with it? *laughs*
It's a V-Spec II right?
Everything looks right from the outside... The clear front signal lamps, the carbon fiber bonnet with NACA duct...
But Wait...
There's something wrong with the interior.
Why is it grey with red stitching?
Why is there a DVD navigation unit below the air conditioning ducts?
Why are 'Aluminum sport pedals' made by "RAZO"?
Fishy eh since it's supposed to be a V-Spec II?
Liner
131
Mistaken identity,
given the vin no 401xxx and its QX1 , meaning its pearl white, its a 2001 or at least 2000 model. As only the series 2 gtr has pearl white and as most 401xxx GTR's are produced in 2001.
just checked, production dates of that car is..
April 2001 and its a vspecII
DarkChild
1,449
674
Thanks Liner...
Here are the colour codes for the BNR34...
BNR34
TV2 - Bayside Blue
QM1 - White
KR4 - Sonic Silver
KV2 - Athlete Silver
GV1 - Black Pearl
AR2 - Active Red
EV1 - Lightning Yellow
LV4 - Midnight Purple II
LX0 - Midnight Purple III
WV2 - Sparkling Silver
QX1 - White Pearl
EY0 - Silica Breath
JW0 - Millennium Jade
A Post Every 5 Mins
I would like to ask all ZTH members, has anyone ever experienced the explosive force of inflating SRS Airbags and would it be alright to share your experienced? :nurse:
The reason I am asking this is to understand further how the human body reacts when opposing energy forces are encountered in an event of a frontal collision. Thank you very much for your kind understanding. :itsme:
