question ~Mod on vios
Nieto
What i can mod for toyota vios beside addin turbo? i dun wan a too noisy engine sound. btw, wat spark plug is most suitable for vios? :proud:
intake and exhaust?
spark plug?why do u want to change it?if its working fine..use that $$ to get hks spf.
Change engine lor...
I have saw Vios with turbo engine already...hehe.. dun knoe what code is that but confirmed its not BOT...
Good Luck...
i think s/plug just use the original one since u still not modi yet..
if u can get the h/cut from Indon or Thai the engine come with turbo and u can get manual transmission..
better then 'rojak one'..
good luck for the modi bro..
lolx, jus dun wan mod till change engine or add turbo, the car still new... sayang if change engine.. so if intake, and exhaust system, wat u all think wic 1 better? and how bout afc? cos after change to 17" gramlight, the car got a bit heavy..
you want more hp, but no turbo, no noise...
then you pump Vpower petrol...
eemm.. good idea to pump VPower petrol..
of cause la 17" quite heavy.. change to 15" or 16" with light weight one
it will give u good ride.. but maybe a bit expensive la (if u done mine about money)
No Vpower, then look for Fuel addictives, they may help..
I using Denso Iridium spark plugs..
lol so many not logic answer come out... aww iridium, how the effect?
The easiest way is get a halfcut then 'rojak' all in then can use back your ori engine lor...
mag,
if get a half cut and rojak everything with new engine, then the half cut a bit wasted, right? hehehe I mean, that's what I think la. hehe
mag,
Aiya.. want power have to sacrify a bit le...:driver:
it cost about 5 to 6K depend on wat u use new part or second hand part. You can check on the vios club website they got few of the menber already install the turbo kit on they car. And 1 of them actualy convert a manual gear box to a N/A car. Or you can try to ask RS Impressive at puchong. They convert a lot of turbo car using bolt-on. Good luck
mag,
erm... true also ler. hehe I see many modded vios on the road these days. one of the common mods is usually front and rear lips or those dumb idiotic white light that's misaligned like shite. darn bloody irritating when it glares at you from behind.
mag,
Aiya.. no choice what.. since that the 'g' said its legal.. we also follow lor... what to do.. change also lor.. planing to change to 12k HID for my kancil liao... really cant stand of those HID people...:mad:
change header 4-2-1, get a gud sflow muffler and not sright flow since u r using auto, drop in air filter,lightened crank pulley, performance plug cable and spark plug :) hope that help...
