D.I.Y Cold Air Intake & Water Injection for Carburetor
amrancharger
779
96
so the funnel need to be as close as possible to the water tank rite.i'd like to try but still scared lerr.hehe..
by da way y u change yr engine??anything else i shud know so dat dun make any mistake ere...hehehe...
Kendconcerto
271
Owwh.......
too bad my engine had a sorethoart, it guzzled up all the water....
Wat should i do arhh, amrancharger ?
amrancharger
779
96
Owwh.......
woa...u mean the water spill n get into yr engine izzit??if u got sorethroat sure got some tips...just take 1 tablespoon of margerine and swallow it.but for cars duno can do dat o not.....hehehe...
but i dun tink i can do like u la.cannot make scoop on my bonnet...my airfilter already too high...tink will buy CAI instead and route it according to my original filter before this...which r behind my right front light.izzit ok??then the water tank will be put into another tupperware that has some hole under it so dat water will go out as soon as possible when it spills out...hehe..duno can work o not...
burnner
1,563
4
guys, i have tested my teory. Its very simple teory. What you need to do is, at our air cond pipe, when its cold, it condense some water. So by putting your air filter hose at the air cond pipe (metal Part) it sucks some cold water in your inlet. I manage to get 100km in second gear, by the way, my car is a standard 1.3 8 valve LE. In the proses, I WIRA did makan some asap....try it, it works for me...
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Hehehehe, just dont let her found out the hole.
that's the hard part bro...
btw...felt sorry for your car got sore throat...maybe the concept need to be redesigned a bit?
Kendconcerto
271
papagoines....
That was a bullshit to answer the mighty amrancharger's sarcastic reply.
hehehe
Feb 27, 2007
yo bro.....that real cool. I would like to invest this project. mail me..k. good job..! keep it out...bro.
Kendconcerto
271
All the best to your project :)
PM me if need anything :shades_smile:
unknown47
28
Dude, you should be working for pimp my ride or something. keep up the good work mcgyver
Kendconcerto
271
You should be graduated from kindergarten to post sacastic meaningless replies
StrayBullet
182
Kendconcerto!
from the looks of the way you install your DCNF. You are going to have a problem with petrol when you turn a hard left. The float bowl is on the right side of the carb. Notice the word K&N is turned 90 deg clockwise? It means you have a wrong installation.
ThunderGod_Cid
303
7
3,018
heheheh... u converted to EFI??
so ur DCNF for sale ar?? hahahaha. gimme a call if it is :
0129096996
Kendconcerto
271
To whom may concern after reading my DIY, plz bear in mind all these are experiements, that most ppl who enjoy filling thier past-time doing some DIY (dont reli care it works or not)it is for the sake of FUN.
So, b4 u wanna comment sarcastically, I suggest u find something better to do coz it will be totally useless to do so, coz I presume ppl who talk these sarcastic words normally dont do much DIY themselves but pay money for the mech to do it.
But that doesnt gives u the credits to critize others.
THIS IS DIY THREAD! So post accordingly, thank u.
Kendconcerto
271
StrayBullet : Yes, it was mounted wrongly in early stage, but I got it corrected by changing a new adaptor after I went to see Ramly. Thanks for the comments anyway, it will help newbies when installing a DCNF.
Thundergod: Yes, convert to something very exihilarating.......But my DCNF is long sold to my fren, maybe u can try going to Log In to look for ppl selling it. Or just go to Ramly's.
gream
139
bro..which tupperware size did u use? buy at carrefour ka?? interested to do it as a heat shield for my open pod la..
proton63t
565
at a plastic ware shop, ask them u want a tupperware can put into microwave to heat up food ones......should be no prob
arsenalboi
1,017
aiya if u want to pay mechanic do lor. lets give the bro credit for his effort in painstakingly taking pics and posting for our pleasure.
C
chilskater
Guest
bro,
if u sealed the box with thin layer of heat resistance foam like superflon, does it makes the box less hot? thus increase performance
Hi there,
Lately a friend of mine teaches me how to clean those hard to reach and hard to clean dirt on your engine block using a cheap and effective way -- Carburetor Cleaner
ATTENTION BEFORE START USING -- this Carburetor Cleaner (CC) is corrosive to plastic, paint and your hand, so cover things that should be covered and wear a gardening glove. Wash your hand with clear water to avoid itchiness.
Just put a cloth surrounding the area of dirt, spray the...
