- Nov 18, 2003
- 10
- 0
- 3,001
Hey bro,
Need to cut hole for the engine bonnet ah?? wahlau....like this...not good leh. Got any other way?
in order to make that shape, u need to buy new one... air filter element cannot diy one lah... unless, u say diy tapak to fit the air filter, possible lar.....KLEMANN said:may i ask sumthing????
is about da filter shape...my car oso run wit carb..but da sized is quite big n round shape like those old classic jap car...
how do i make tat shape coz i find its different from ur proton stock engine.....
hehe, i was telling tose tat r going to do tis DIY, else they will think biger holes r better....Kendconcerto said:xtorm,
This issue had already taken into consideration. My airbox is atually tilting to the left slightly, all rain water till flow sideways n drained from the hole drilled on the box.
Actually I myself is NOT an engineer or researcher :tongwink:xtorm said:hehe, i was telling tose tat r going to do tis DIY, else they will think biger holes r better....
u better write some warning there :P
Kendconcerto's idea is the same as most rally teams used to in their cars...his version are for carbs application...or maybe your engine sudah jahanam cause mix with too much water???
safer way is just use your car air-cond pipe, just lay them along the inlet of our air filter hose and when you on your air cond, then you can get cold air in your car/efi also...at least during hujan lebat, tak banjir la cab????
