D.I.Y Cold Air Intake & Water Injection for Carburetor
Sophisticated
10
Hey bro,
Need to cut hole for the engine bonnet ah?? wahlau....like this...not good leh. Got any other way?
unknown1x
369
lol.. efi.. can do also.. heheh i got the whole plan stuck in my head.. but. ur scoop.. have to be side abit lah.. hahahaha
best way is cut hood .. by cutting hood. you wil have instant air compare to cold air intale which scoop from front = more dusty air. nand needs to travel some distance.. in still insist on doing cai style can.. go get 2 3-4 inch one... intake from ur bumber, connect into box! wala! there u go! haha
Kendconcerto
271
xtorm,
This issue had already taken into consideration. My airbox is atually tilting to the left slightly, all rain water till flow sideways n drained from the hole drilled on the box.
KLEMANN
62
may i ask sumthing????
is about da filter shape...my car oso run wit carb..but da sized is quite big n round shape like those old classic jap car...
how do i make tat shape coz i find its different from ur proton stock engine.....
SkYwAlKeR
10,146
300
ePoh ~ malacca
in order to make that shape, u need to buy new one... air filter element cannot diy one lah... unless, u say diy tapak to fit the air filter, possible lar.....
ohya, kend taikor not using standard proton carb ler... thats why his K&N filter looks different.... different filter model to fit different carburettor....
Kendconcerto
271
ahem............ :P
xtorm
1,590
49
Kendconcerto said:
xtorm,
hehe, i was telling tose tat r going to do tis DIY, else they will think biger holes r better....
u better write some warning there :P
KLEMANN
62
oic......anyway to all senior member my car using 4G32 is a mitsubshi engine n car as well...do u all know tis 4G32?????? got any tips to how to maintain engine especially carb...is driving me crazy.....
Kendconcerto
271
Actually I myself is NOT an engineer or researcher :tongwink:
The size of the hole, I just follow back the size a regular stock 1.8 airbox (About 2.5 inches) Nearly the same size as my exhaust :regular_smile:
Kendconcerto
271
I think you are right, xtorm.... Thanks for the enlightenment :)
Nulla Chongla
17
Just bloody brilliant!
That's the best DIY thing I've seen on an Iswara in a long time.
Kendconcerto
271
Anyway, this setup nolonger with my car now, I converted into EFi.
but the DIY was rewarding, the effect was really there.
Thanks for the comments :)
burnner
1,563
or maybe your engine sudah jahanam cause mix with too much water???
safer way is just use your car air-cond pipe, just lay them along the inlet of our air filter hose and when you on your air cond, then you can get cold air in your car/efi also...at least during hujan lebat, tak banjir la cab????
Kendconcerto
271
Check out the pictures in PAGE 1 before you comments.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Kendconcerto's idea is the same as most rally teams used to in their cars...his version are for carbs application...
basically, this idea known to lower in-cylinder temperatures and burn the air/fuel mixture more efficiently thus helping avoid detonation.
Please read "How a water injection system works"
Nice work dude...I'm looking for CAI/Water solution for EFI but I found urs instead...very enlightening...wonders my mom would let me drill holes in her iswara's bonnet :X-:
Kendconcerto
271
Hehehehe, just dont let her found out the hole.
A Post Every 5 Mins
Hi guys,
Anyone know any reliable, friendly and reasonable price workshop, tyre shop and accs shop in kepong area?
