Gear box also, right? If mod too high the BHP......i heard.... those guys who convert the exora do face some cooling related issues, so do take note.
Alza like pocket rocket if got power, Exora is huge......TS seems pretty adamant on a power house MPV for trackdays. Well if u must, this would be easier done with the Exora. People are already dumping serious power into em, gsr conversions, evo conversions and mivec 1.8 etc. But if the only reason you wanna track an MPV because its your family carrier i suggest get an mvp and keep it as a family carrier. Then buy a cheap second car to play. Heck even a proton saga would work. you can play with suspension upgrades and stock engine. Chances are it is still better then a family mpv on track as you will be able to have a proper suspension set up instead of something with a comfort priority.
exora when they convert, semua ambik evo...Gear box also, right? If mod too high the BHP......
Earlier on, some boost engine power higher only......exora when they convert, semua ambik evo...
true, but you also get a stiffer chassis :p of course light weight has alot of advantage too.. pros and cons.Alza like pocket rocket if got power, Exora is huge......
