KHNG940413
668
56
johor bahru
Did you see my comment about the wobbly crank pulley? You should be able to visually inspect the pulley. Start the car and look at the pulley turn. If it wobbles then you potentially have your culprit.
China crank sensor - but was it made for your specific engine or a generic VDO sensor?
I have start the engine and inspect. Didn't have any wobble.
Yesterday I checked and try wobble the crank sensor itself at the bottom side and the car died same as the car usually went dead.
Not sure as I never see the package.
parakey
1,367
226
Use my hand and goyang like pusing your kopi while the milk is at the bottom. Hahahahhaha
Not very hard juz slightly goyang only
There's a reason why I asked. The sensor's position relative to the trigger wheel is supposed to be quite immovable. It cannot be "longgar" to the extent where a small force may deflect it. This will cause the sensor to miss a read and stall the engine.
Have you gotten a multimeter yet? Check to see if sensors are really faulty.
Reactions: Izso
KHNG940413
668
56
johor bahru
So what you mean is maybe my sensor is crooked is it?
KHNG940413
668
56
johor bahru
eh... you are not supposed to be able to shake the sensor bracket and all la wahlau... anyway it's beginning to sound more and more like sensor problem
I am not shaking the bracket sensor lah,hahahaha
I juz hold the sensor top wire tarik abit & goyang abit see will it make the engine dead.
Juz now I go to spare part shop and ask for Original Proton crank sensor is around RM190.
Haven't bought it yet since my car now still running ok....for now....hahahahahah
15,390
You skimped for 190 bucks? Man oh man - chinese sensors are never good. Even those aftermarket meters using chinese sensors are rubbish.
Reactions: sanekit
KHNG940413
668
56
johor bahru
No lah, tomorrow only go and buy. Juz pass by and ask them 1st. Will update after installing the original
Sensor
sanekit
Dec 9, 2015
1,616
157
Sensor
maybe it it caused by the china OEM sensor. haha. coz if i remember correctly, VDO is a bit choosy with sensors.
and as @Izso and @parakey mentioned, the sensor supposed to be tight and snug at it's bracket/holder. it's not supposed to move even if u try moving it with your hands.
minibeany
599
102
543
yeah... kena before... put in a OEM sensor... problem persist... When changed to original sensor problem solved
Reactions: sanekit
The highly popular 1,5L Vios has been facelifted for 2021 and is set to arrive with a new sportier face and a range of new safety features. Bookings are now open and will begin now via online and the dealerships. The newly enhanced Vios, with its Toyota Safety Sense (TSS) that includes pre-collision system (PCS) and lane departure alert (LDA) earn it a 5-start ASEAN NCAP safety rating...
