I think the seller doesn't even know. Hahahaha.It's quite unfortunate. Seller wasnt that truthful either.
Serious? Previous owner drive without problem or he/she park the car only. ?I think the seller doesn't even know. Hahahaha.
The owner is much toward the ricer part hahahahaha. He only focus on upgrade the sound system & the interior of the car only. 1st time U go and check the car is below a tree with a lot of leaf on it.Serious? Previous owner drive without problem or he/she park the car only. ?
Sadly, u can't. it'll cost a lot to swap oso iinm. EDITS: after some research, reason is the 4 speed auto uses transmission control unit which is not compatible with the siemens ecu. maybe u can ask your mech if it's doable. if can, do install an atf cooler for the 4 speed auto.I would like to ask a stupid question.
4g15 can slam a 4g93 auto gearbox in it?
Juz curious only since 1 is 3 speed 1 is 4 speed.
Survey before.Sadly, u can't. it'll cost a lot to swap oso iinm. EDITS: after some research, reason is the 4 speed auto uses transmission control unit which is not compatible with the siemens ecu. maybe u can ask your mech if it's doable. if can, do install an atf cooler for the 4 speed auto.
swap 4g92 or 4g93 single cam jer. if got extra can go for 4g93 dohc, and BOT after that. hehe
In KL, 5k you can get Satria Gti engine complete from half cut.Survey before.
Half cut 4g93 1.8 soch cost around RM4800
Installation RM1500
Total RM6800 is quite some money there.....
Even if I swap it they don't makan your old engine & gearbox is quite pain in the axs. Also need space to store it & sell it. I dunno why Johor halfcut quite mahal.
Wow,that is quite a bargain!!!In KL, 5k you can get Satria Gti engine complete from half cut.
I think the thing you list is the thing I haven't chg.Bro KHNG940413, if you are contemplating engine/gearbox change, I have to ask you what's left of the old car which you havent replaced. What's left?
* Alternator
* Steering rack
* Drive shafts
* Power steering pump
* Exhaust system
What else ?
You do realise that apart from the rear trailing arms, you have replaced your entire undercarriage including the wheels/rims.I think the thing you list is the thing I haven't chg.
Hahahahahaha
Other then that I really change already.
Still budget la. Now I juz swap the the spoil part only. Didn't modify anything lehhhhh. Hahahahahathis wira was supposed to be a budget car yea? looks like this took a 90 degree turn
Didnt notice you were in Johor. But in my opinion, a 1.6 auto sohc and 1.8 auto sohc not much different. The 1.8 can get more top speed la but on average about same same jer. The dohc on the other hand is a different breed. HahaSurvey before.
Installation RM1500
Wait wait... Before u plunge into repair all back to stock, think deeply.Still budget la. Now I juz swap the the spoil part only. Didn't modify anything lehhhhh. Hahahahaha
If New year Bonus kuat I might consider modified abit...Juz abit...Wait wait... Before u plunge into repair all back to stock, think deeply.
Later u 360 degree turn...monster wira yo!! . Hahaha
Money not easy to print.
yes. some change to persona or lancer coz it's 1 solid shaft. mine i'm using the adjustable ones.These are the old arm took out from the car. I found out that the ream lower arm is juz U shape compare the 1 I bought it had a extra plate cover it.
Now the car is more solid and no weird squirking noise. And handle a lot better.yes. some change to persona or lancer coz it's 1 solid shaft. mine i'm using the adjustable ones.
* Alternator
* Drive shafts
* Exhaust system
Sorry. My mistake. If change engine, I think the 4 above also will be replaced. Just left with one
* Steering rack
If can find a 4g93 Dohc auto sudah cukup makan lah~~~Sadly, u can't. it'll cost a lot to swap oso iinm. EDITS: after some research, reason is the 4 speed auto uses transmission control unit which is not compatible with the siemens ecu. maybe u can ask your mech if it's doable. if can, do install an atf cooler for the 4 speed auto.
bro,If can find a 4g93 Dohc auto sudah cukup makan lah~~~
Juz drive to work & sometime go to vacation only~Hahahaha
That is why VR mostly for own use. Wife go out use her forester......lolbro,
many here include me says "cukup makan" drive to work only la, fetch grandma only, go market, gf/wife don like harsh ride..etc
only money can restrict how deep the poison can go in. wakakaka....
sadly the itchiness is always there.
can bro. don't be like me. mod single cam auto. ended with 130whp & 18kgm at the wheel but still not enough. need more.If can find a 4g93 Dohc auto sudah cukup makan lah~~~
Even if you have mod higher, once used to it, will want more......hhahahhahahahahacan bro. don't be like me. mod single cam auto. ended with 130whp & 18kgm at the wheel but still not enough. need more.
