Conversion GSR 1.8 Turbo (4G93T) - Wira/Satria/Putra
niklys
118
18
18
Selangor
as long as u have bodyshift function and soft-hard function on adjustable, then easier to tweak the setting later
Yeah, going to go for full threaded coilovers. That extra customization option is going to be warmly welcomed to get the right settings for my car.
Though, any good brands nowadays that we can choose nowadays? Secondhand orfirsthand, as long as serviceable, is fine. Was thinking Cusco 6k/4k or AR Racing would come to mind.
niklys
118
18
18
Selangor
Just survey around on the cost of rims and tyres between the sizes before you decide and also tyre choices and availability....
I’m planning to put aside 3k just for wheels. If a little extra is needed, wont mind going for it. Any brands out there that we can go for?
niklys
118
18
18
Selangor
In total, my cash budget is rm35k for this project (all-in, GSR swap, support mods, etc). Wonder how should i break it down hmmmmm
sweelt
Nov 6, 2016
2,306
248
on the safe side you set aside 15k for halfcut + replace wear n tear parts.
left 20k .. :smokin:
If brand new....
There is hwl st1 or nearest version...
For used, cusco, tein and several other common brand is to ensure easy servicing later
sweelt
Nov 6, 2016
2,306
248
If brand new....
HWL st1 is 8k/4k , maybe i got lemon one or installation problem (not by dealers). No leaked, everything in order.
Steering feel so light like feather above 90kph. During that time i also noobs, din try 6k spring.
"I not sure whats happening". Everything checked, steering rack, tie rod, alignment...etc all OK. Try many dampening settings. I give up after 9mths.
After replaced other brand 6k/4k the car feel planted.
sanekit
Dec 9, 2015
1,616
157
it feels like above 90kmh coz 8k springs. have u tried set to the softest damping? u changed to 6k/4k what brand ah?
sweelt
Nov 6, 2016
2,306
248
All dampening setting tried. ..
i din say spring problem, i "miss" out to try 6k spring instead before i closed the book. i already mention maybe i got lemon coilovers or installation mishaps.
Change to ftuned. All this 2yrs ago.
Maybe 8 too stiff. In fact I feel my old suspension on my vr more planted too. Got this new set from a friend. The front he fitted to his ride but seldom use, later he cancel his project so I ask him to sell the suspension to me. The rear kept at his home, so is practically new. However find them stiff, even at softest setting, it jumps a lot, don't have the planted feel.....lol
parakey
1,367
226
So what springs are you currently on?
sanekit
Dec 9, 2015
1,616
157
ah ok. forgot you're on ftuned.
Actually I don't know because considered used set. Packing he threw away already.....lol He saw and sat in my VR then consider building one himself. then along the way gave up.....
stock default spring is 8k/4k... what i usually did is asked them to swap different spring rate fresh from the box....
u should just swap the springs...because almost all adjustable suspension spring is swappable without any problem.. (except some brand like TEIN front spring is in bigger diameter coil and other expensive brands)
Lexus recently ordered a worldwide recalls of its LS models due some problems with the steering wheel's Variable Gear Ratio System. The VGRS system enables easier handling during low-speed driving and provides better stability during high-speed driving than conventional steering by changing the gear ratio.
The VGRS system may exhibit a temporary steering wheel off-centre condition after driving away quickly from a...
