Conversion GSR 1.8 Turbo (4G93T) - Wira/Satria/Putra
parakey
1,367
226
If brakes issue then cannot be helped, you need larger rim/tyres. Most still use15 over 16 is because of tyre choices and orice
You can leave tyre sizing for last. I assume you're currently on 15 now. So after engine change, see how often it squeals and gives up traction. If you cant get the tyre to squeal, why make your wallet squeal?
sanekit
Dec 9, 2015
1,616
157
Now that you mentioned torque, would a stock GSR that's overboosted 1.0 bar with locked 4wd autobox be able to produce more than 35kgm or 350nm? Don't think it's possible, isn't it?
Your autobox is from GSR? It comes with eco/power mode? What would the eco/power mode do? Does it delay the gear changes in power mode to a higher RPM bandwidth and vice versa with eco mode? It'll be great if you can share a little on the autobox twerks.
Also, I don't think stock GSR can go beyond 180 due to speedcut, isn't it? Pivot, RSM, or some form of speedcut alteration device is probably required. I'll probably do it too once I have GSR swapped in my Wira.
In this case, I'll need 6k spring rate for front coilovers due to the autobox? It's that heavy ke? Oh my.
I live at Kota Kemuning. Is it near to AEON Bukit Rimau by any chance?
GSR autobox is rated at 26kgm torque. You can push it up to 10-20% more from the rated max torque.
Yup. My autobox is from a 93T gsr. The way my mech does it is they just remove the transfer case to make it run as 2WD. No need to lock any gears.
ECO mode runs the torque converter at low rpm and doesnt let you hold the gears until redline. It'll shift at 2.2k-3k rpm. Cruising at 140-160kmh, the rpm is low in the range of 4.5k-5k rpm (auto revcut is set at 6.5k rpm). PWR mode (or HOLD in some models) runs the torque converter at higher rpm. It'll pull the car way faster and let the gearbox run at its specified gear ratio. Meaning, it'll cruise like a short ratio gearbox. Cruising 140-160kmh, the rpm is in the high range of 5k-5.5k rpm. Mind you, the final drive for the gsr autobox is 4.7 and it takes 8 litres of ATF if you empty it. Also, the gearbox is twice the size of a standard 2WD autobox. Hence the need for 6k springs at the front.
Install pivot or remove the revcut at the ECU.
My mech is at Jalan Bukit Kemuning. Upwork Racing Workshop. PM me and we'll set a time we can go to the workshop and get a proper quote.
sanekit
Dec 9, 2015
1,616
157
reply already! hahahahah
stock with light mods? different people, different definition of "light" hahahahah
though, would overboosting from 0.6 to 1.0 bar be tolerable for the engine? reduced lifespan is understandable, though, not pedal to metal from every stop should be fine qua, kan?
1 bar boost with stock internals ok laa. no worries. get piggyback or management to fine tune it.
sanekit
Dec 9, 2015
1,616
157
Was thinking 16 inch incase my Evo brakes cant fit nicely. Also, tyre choices macam wider. 205/50/16 should have the same amount of sidewall or slightly more than 195/55/15, so should still be able to absorb the road similarly like yours. Just that, any additional/unnecessary unsprung weight would be bad for FC and pickup lu. Sakit one time, janji drive syok hahahah
evo calipers can clear aftermarket 15" wheels. hehe
Nice way to put it, make wallet squeal......hhahhahhahaha
parakey
1,367
226
Memang wallet bising. First time buying not so painful cause you have expectations.
Later after getting used to it & have to periodically replace, you will hear more of the gut wrenching sounds..
15" can get sub RM200 some times, if not RM200 plus. Performance 17" mostly double up......lol
niklys
118
18
18
Selangor
You’re right. If we cant make our tyre squeal, why make our wallet squeal? Hahahahaha!
Though, to clear Evo brakes safely, probably will go for 16, just to have a little more clearance for the wheels and brakes.
Probably going to give 6k/4k a go, since the box macam heavy and my rear also heavy.
Since i might have 3 people sitting at the rear once awhile, i think 4k spring rate is required. Daily drive, sure got people sit de especially my team members for lunch session. Janji dont sagat can d hahahaha
as long as u have bodyshift function and soft-hard function on adjustable, then easier to tweak the setting later
Just survey around on the cost of rims and tyres between the sizes before you decide and also tyre choices and availability....
Audi, a superior piece of German engineering*but today we are here to make this into Art. This is a Audi A5 5 door sportback, With more than 50,000KM on the ODO, this car came a long way to Malaysia. Although the car was relatively new, local car dealers will not let it live as it as but instead will sent it to be reconditioned. Reconditioning involves respraying, painting the rims, greasing up the engine bay to...
