Can change to slotted disc and better pads will improve quite a lot already.....
yes same. don't bother changing to alzas or myvi 1.5 since there's no performance gain
Can change to slotted disc and better pads will improve quite a lot already.....![]()
Is that the RSS brake kit?
Yes, I want to upgrade the brakes for my alza. I want to see what are the options, BBK is out since it's a overkill unless I TC it. Haha.. can't seem to find much performance upgrade online.
You can look for bigger rotor and caliper such as Honda Oddessy. Its a plug and play for myvi. I guess its the same for Alza too. Other than that...just use better brake pads. I would say first thing to try is changing to better brake pads. Im using drilled and slotted rotor on my myvi. It doesnt improve the braking distance however the braking is much more consistent and they system doesnt overheat that fast.
Upgrade brake pads, master pump, brake servo. Whatever not involve major fabrication. Don feel so pain...
Yup, usually just brake pads and disc first then plug and play bigger servo then won't have major stuffs to mod....lol![]()
any specific brands to recommend?![]()
mine is the latest facelift Alza, got it few months back only![]()
i don't want to change the rim size if possible. Using the stock 15" from Alza advance...will honda odyssey calipers fit? or is there any other plug and play... cause fabricating bracket could be a hassle.. last question is how much will the estimated cost be?
Habis already haha...it was selling like hot cakes
Anyone know where can I get the clips from?? I search a few spare part shop in PJ area, they don't have it...
