S90 throttle body sticky
pac_jb
131
14
Hi,
Anybody facing this issue, s90 70mm throttle body becomes sticky after the engine warms. It's very hard to drive during traffic jam, I tried to adjust the throttle body cable pulley screw , helped abit but still sticky.
hazziq
46
1,508
Well u better get it sort out quickly,
last time my throttle just suddenly got stuck at WOT.
End up ditching s90 and went back to stock
what i heard from other fellow mech...
need to do some spring mod at the butterfly to reduce the spring tension so that it doesnt becomes sticky.... (probably shaft lubrication/minor adjustment needed also)
Reduce? not strengthen to put the TB back?:smokin:
g4i8y0t
1,216
330
683
Kedah
Hi,
Try lubricate the throttle cable. I once faced this issue too, turned out it's actually the cable that is causing problem.
egb18c
922
94
kuantan
Or maybe the valve expand at higher rate than the body of the throttle body, thats why its only sticky after a the engine is fully warm.
pac_jb
131
14
The throttle feels better now, I adjust the throttle cable pulley screw again two full turn anti clockwise, the pedal feels more softer now
The highly anticipated Nissan GT-R, which will be available for the first time ever in the United States beginning in June 2008, made its North American debut at the L.A. Auto Show, following its global introduction at the Tokyo Motor Show last October. Nissan was also kind enough to announce U.S. pricing of the 2009 Nissan GT-R which is equipped with a twin turbo V6 engine producing 480 Hp. On this side of the pond...
