Racing Throttle Body
customDIY
Brand New S90 Racing Throttle Body for sale
, Suitable For Honda B/H/D/F Series DOHC & SOHC V-tec Engine . 70 MM Throttle
Vent , more than 100 pcs of ready stock . Export quality
The S90-Racing Throttle Body is the Breathing Point of your engine. With a Larger Oversize Throttle Body, you can supply as much Air as the Intake Manifold demands. Whether you have a set of Aftermarket Cams, Supercharger, Nitrous or Turbo, Oversize Throttle Bodies will deliver More Horsepower! Oversize Throttle Bodies work well with Fuel and Air Upgrades. Use of a High Flow Air Intake is required, as the opening is larger than the Stock Intake Piping. Match Porting your Intake Manifold will help Maximum the Larger Throttle Body Diameter.
Most companies simply bore out the stock throttle body and change the Butterfly. Not S90-Racing! S90-Racing Throttle Bodies are made from CNC Billet Aluminum AL6061 and are a direct replacement for the OEM Cast Throttle Body. A Special Billet Throttle Blade & Shaft made from AL7075-T6 is included to increase Full Throttle Response and Acceleration, especially installed at Force Induction engine. AL7075 material can stand for highest boost pressure to 3 Bar we tested , Both side of the shaft was comprise of Branded Ball Bearing to put out the best respond. You will need to reuse your stock Map Sensor and TPS. These can be reused from your stock throttle body. We have our own Design & never copy from any other’s Manufacturer .
Intro:-
* The throttle body unit was made from Precision CNC machine & material are
Aluminium AL6061 - T6 Billet
* The throttle shaft & Blade was made from AL7075 can stand for more higher
boost
* We been tested at High Boost 3 Bar & Normal Boost 2.5 Bar Engine
* Throttle body was done by Hard anodized coating to increased Durability
* T/B unit material can stand up to 350 c
* Both side of the shaft was comprise of Branded Ball Bearing to put out the
best respond
* Plug & Play easy install
* Stylish design
1 Year warranty of our Throttle Shaft , Blade & Ball Bearing .
For more further infomation pls call
Inquiry for OTB PLs contact RS One
Tel : 03-62777768, 62777713,62777723
017-8922633
60177791517 Vincent
Mail add : [email protected]
Simply way to increase Horse Power without Modify . Plug & Play !
Quality is everything , Plug & Play with stock sensor . High Grade Material will Contains Certificate we promise
Bump: Quality is everything , Plug & Play with stock sensor . High Grade Material will Contains Certificate we promise
Bump: Dear Skytech
Can install at 4G91 w/o any modification .
Bump: Dear Skytech
what about 4G93 twincam?? can it fit for 93 as well
