When you say machining I assume you mean skim the base and PNP job? As long as you're careful with the skimmed surface, it doesn't matter which you do first. Personally I did the valve after the skimming. I also did a few other small things like powerlynz which needs to be machined on the valve itself which explains why I didn't lap the valve first. Then there was the Singh groove.
I jez finished cleaning the head...i just need a common head job.....its a 13 y.o. motor...1st time diy
PNP = smoothing the intake port rite...1st stage?
---------- Post added at 11:49 AM ---------- 6 hour anti-bump limit - Previous post was at 11:35 AM ----------
Is this considered clean? The diy is way off schedule..
We’ve all wondered what it would be like, but few could actually get the chance to put it in practice. What are we talking about? It’s a direct comparison of between...
