MTF as in Manual Transmission Fluid? but his is ATF woh!I use Toyota MTF, very smooth shift. but make sure its genuine.
Oh! your mention of ATF was for reference only.....hahahahahe quoted his is v6tt manual, both recommended to use Toyota brand.
thicker or thinner grade is better oil for manual transmission sifu?Oh! your mention of ATF was for reference only.....hahahaha
If MTF then no problem, can actually mix with other brand. 75w/90, 80w/90 or even straight 90 also can.
Manual cannot be too thin. 75w/90 will be good. If not 80w/90.....thicker or thinner grade is better oil for manual transmission sifu?
Usually the front and back ones at the bottom will give way first. If these two are not changed then affect the other two left and right ones on top. Mine usually just change the bottom two front and back ones.Yup change all 4. Once I took the old out all the rubber bush fall out...
