Why is my radiator got mixture of oil wit water? I did flush the radiator n fill it back wit water and flush it again the next day. The result still the same. I wan to know where is the oil leak in and wat is the negative thing will happen?
Check your engine oil see got water or not? It will turn milky if there is water.Why is my radiator got mixture of oil wit water? I did flush the radiator n fill it back wit water and flush it again the next day. The result still the same. I wan to know where is the oil leak in and wat is the negative thing will happen?
bro will help u on the budgetshould b using normal gasket... haiz lot of problem in the list need to repair n check....
1. engine mounting
2. absorbed
3. all the bushes.
4. power steering rack.
5. radiator oil leak.
6. etc
I got my 555 tie rod end at RM60 per pair woh!bro will help u on the budget
1. engine mounting - rm45-55 per pc
2. absorbed - go straight for adjustable hotbits, tein, gab, etc....2nd hand also can. look in mudah.my
3. all the bushes. change the important ones 1st, lower arm (rm150 per pc 555 brand), tie rod end Rm60 per pc, 555 or ori proton.
4. power steering rack. - can recond but not sure how much.
5. radiator oil leak. - get this fixed 1st but make sure u dun bring to your mech where u service your bimmer.
Ooo ya I think its rm60 per pair kua.....:hmmmm:I got my 555 tie rod end at RM60 per pair woh!
Should be, because one box got one pair, they don't sell by piece....Ooo ya I think its rm60 per pair kua.....:hmmmm:
head gasket kong liao...Why is my radiator got mixture of oil wit water? I did flush the radiator n fill it back wit water and flush it again the next day. The result still the same. I wan to know where is the oil leak in and wat is the negative thing will happen?
