mods on Accord CF4
Sil80-13
1,215
44
1,648
1. I saw 1 button which is EPS. Is it mean (Electronic Power Steering) as I can't see any power steering pump in the engine bay.
2. I am being inform that Euro R using electronic steering rack which it will have check light ON when it reaches 200k mileage. Is it true? If yes, can we just clear the check light? Or we need to replace the steering rack?
alwhitesat
760
30
eps is electronic power steering. it doesnt have pump, and it has it's own eps module which runs like it's own ecu...u can set the steering setting, -/0/+ which is soft/intermediate/hard. eps is one common issue for most of owners here, normally...so, u must not change the setting unless ur car at idle, and the price of 2nd hand rack and module is around 300-400 ringgit, depends on your luck, and, if there is any fault on the eps system, the check light wont lit up, it has it's own eps warning.
come this sunday and i'll explain more to u!!!!
Sil80-13
1,215
44
1,648
I see. So when the mileage reaches 200k, will the check light ON? And is it compulsory to change the steering rack?
Sil80-13
1,215
44
1,648
don't change anything unless it is not working :)
Of coz i will not change it if its still functioning. Jz want to knw when d engine mileage reaches 200k,will d EPS or check light ON? as i being told frm a fren.is it true?
aja
4,696
35
5,148
Who else attend this Sunday?
What is the program like?
SemuaPutih tolong sms cerita sikit..
Sil80-13
1,215
44
1,648
so untrue!!!!!!!!
IC. Will check it when reaches 200k mileage...Lolz...
By the way, how about the steering? If I wanted to keep the DC5 steering, can bypass & make the SRS airbag lights goes off?
This Sunday I can't confirm as I am down with FLU. Not sure can recover or not... :bawling:
alwhitesat
760
30
830 am- rv at bhp petrol station
900 am- departing to genting
930 am- lepak2 while having breakfast...tak tahu mana mau lepak, time jumpa kat bhp kita discuss
1130 am- turun genting, short touge lalu ulu yam n back to kl
1230 am- lepak lagi, tak tahu kat mana...those who have work or need to leave can do so
yg ada:
alwhitesat
shahrul
idie
faiz
hizal
jimmy
najib
cat77
aja
Sil80-13
1,215
44
1,648
Hi guys,
Today I tested my H22A. Realize that the rev cut is around 7200 or 7400rpm (din really see). This is the standard rev-cut for H22A redtop?
BE5RSK
343
125
Besaout
Mine redline at 7400rpm...
But I never really push it until redline, mostly around 6.5k to 7k of rpm, then I shift up.
For me, H22AR got plenty of torque (of course in NA manner), thus it doesn't really need to push until 7400rpm.
choon meng
49
5
1,508
i think for a standard h22a engine maximum hp rev untill 7400rpm only. it is no point to going more rpm which the hp going drop after this limit. unless u have balancing ur engine and up grade it.
choon meng
49
5
1,508
is it? but i dono my ecu rpm cut, just know the engine hp is drop after 7400rpm. i guess my ecu cut at 9k!!
wafuk
May 6, 2011
23
5
503
Hi guys,
1. Just wondering how can we differenciate on the H22A VTEC Type R engine & H22A VTEC Black Top engine? Can we confirm it with engine number? If yes, is this engine number belongs to H22A VTEC Type R Euro R engine? H22A 5005212...
Someone told me Euro R engine number starts with H23A...:confused:
2. Is it better to keep the exhaust system original or we need a bigger exhaust piping, extractor & rear mufler for better performance? Original size is 2.3"? Is it good to mod it to 2.5"? Need advice here all sifu...
3. If steering already change to DC5 steering but the SRS lights on in the meter, can we reset it? Will the DC5 steering air-bag still in function?
bro, just sharing some info.. CL1 H22A Euro-R (Accord) engine number starts 500XXXX; if CL1 H22A Euro-R (Torneo) engine number 510XXXX. H22A Sir CD6 engine number start 200XXXX and onwards. H23A is CL2 and code named not Euro-R (if not mistaken) with engine number starts 202XXXX and 210XXXX..
cat77
3,865
16
Hello.......bila nak TT ni? Pg Puchong singgah le Putrajaya!
haiyaaaa.....not sempat la abe dolah......always balik late one......hehehehe.....later we ask alwi to held a big TT.....:biggrin::biggrin:
fobs
3,752
Anyone have the EPS Module and steering rack for a CF3 for sale? I need one bad!!!!
hold on ED,... we will get some experts here to comment,...
just ensure us that your cf3 is jdm or wat? rhd or lhd?
and bien, if you're around, could the cf4 or cl1 rack/module fit?
we've got plenty of them here,..... and i'm swapping a cl1 one into mine at the moment, since i'm having a major service being done.
---------- Post added at 12:22 PM ---------- 6 hour anti-bump limit - Previous post was at 12:19 PM ----------
correct
not true
so untrue!!!!!!!!
so true
pening,...
fairy
644
Hi guys,
mine was at 8200
not true.. my eps died b4 100k... and trust me, you wont be worried bout check light.. you'll be worried if your arms are not as strong as malek noor the muscle man... hehe.. and when that happens you will be looking for a replacement set urgently.. taking corners at 200kmh is real nice with a kong eps..
abang faisal:itsme: salam and hug hug.. hehehe
not too difficult, use 2nd or third gear and rev till max and you will know the cut:)
halooooooooooooooooo
abang cat... :):itsme:
abang fobs:itsme:
oh ya, met abang semuaputih at exhaust shop.. sempat tt together :)
---------- Post added at 06:25 AM ---------- 6 hour anti-bump limit - Previous post was at 06:23 AM ----------
hey geng.. where is bro sato??? sato san.. where are you? and how is things going with your chick?? i got 1 very nice and good girl to recommend you...
Sil80-13
1,215
44
1,648
Why everyone's H22A rev cut not same? I thought all should be same for the rev cut. :confused:
Hi..
Help needed...
I have just lost my car spare key (with remote) after my car window broken... What can I do now to prevent my car from stolen ? Do I need to install a new alarm system ? Is the car existing alarm can be reset?
Thanks
