wastegate not opening can be because it's jammed up....that would definitely cause an overboost...
maybe there's a vacuum leak somewhere..??have u checked all hoses for any leaks?
anyways, check compression and timing also...
have u checked for any error codes..?
Happenned to me before...it's a faulty wastegate..or wastegate actuator
don't press your luck on cheap knock off wastegates. overboost could cause your engine to break! that could cost your more money to replace the damaged parts instead of investing in an original TIAL/TURBOSMART wastegate in the first place.
Tial MVS 38mm genuine cost Turbosmart Ultra-Gate38 (new version) is now at MYR770.00 complete with flanges.
I have them if you are looking for fail proof boost control.
unlike blow off valve at least your engine won't overboost.. so I won't use luck for performance!
I've heard that our engines are designed to run best with quite LEAN settings...is that true??
Guys,
Sorry to be interrupting the conversation that is already going on. I just couldnt seem to find a better place to post my questions. Please bear with me.
Background
Its been quite sometime since i last visited the site, it was back in 2008 when i wanted a GSR Auto Halfcut. Got a 4g93t Auto RS halfcut and converted the car. Was actively using the car for the first 1.5 years, after which the car has been lying idle. Was thinking off selling the car for the past few months as i already have another car, but just didnt have the hearts to let go. I use a GSR but am not technically very competent, and didnt mod (only exhaust and drop in filter) or had any repairs since conversion. But of recent, am facing some problems (maybe cos never really touch the car for soo long) and am just thinking of doing some mods.
Questions
Would really appreciate it if you guys can help me out with my questions.
1. Car seems not as fast or responsive as before. How much would a overhaul cost? Whats the diff btw top overhaul and full overhaul (my car mileage is 105k).
2. Is it necessary to change the fuel regulator (am using my original 1.5 fuel pump)? Do we get extra HP for it? What is some of the good one's and how much would it cost?
3. Can i use a 'open pod' air filter for an auto car?
4. The turning radius is really bad, wanna do u-turn must be careful. (Could it be because the halfcut i got was a Libero GT Halfcut). Am only using 195/55/15 inch rims the rims are already jetting out of the body by almost 0.5 inch from the body
Sorry for the long long essay guys!![]()
Bro Solty8, thanks a lot for the info.
- i will check the turbo whether it needs servicing or not.
- Almost 5 months never touch the car, so i think i will change the engine oil. Could also be the reason why the engine feels very rough.
- am using the 1.5 fuel pump. I still have the ori GSR fuel pump. Is that sufficient? or is an aftermarket fuel pump like walbro better? And is a fuel regulator necessary?
Any good place that u can recommend for me to check and service the turbo? estimated price how much bro?
hi guys,
just wanna share ask for your opinion..
i just change my clutch to exedy racing clutch. bought RM850. reason because the old one is not good anymore, the engine is shakes when it start to run (gear 1 and reverse)
the clutch is satisfied at first. the grip and pickup is better. the problem is when it come to traffic jamm. gear 1 always stuck (sounds krrrkkk) only when traffic jam. i need to go to gear 2 first then change to gear 1 then there is no krrrkkk sound. But when traffic is clear there is no problem in gear 1 (no krrrkkkk and no need to go to gear 2)
Do you hv any idea why this krrrkkk sound occur? please advise!
TQ
Hi Guys! Will a Walbro 255lph Upgrade causes our cars to increase fuel consuption? thanks!!
5 months never touch means u won't know what happen to ur car, was it parked inside a garage ? Or outside gettin rain and sun ? Sometimes condensation could happen and water seep into places we never want it to go especially inside our engine or spark area. Another reason could be the fuel pump have problem edi, not sure how it happens but usually if a car is slow or can't start usually I check the battery , spark or fuel pump.
The GSR fuel pump should be much better and could feed ur car with as much fuel it needs as possible. If u wanna soup up ur car can always go for bigger fuel pump since ur takin it out to do a swap but unless u wana spend more best is to use ori. Fuel regulator I haven't use yet, so no comment some say very effecient, some say nothing much. Oil catch tank is quite good actually especially if ur using 4wd oil tank.
To check and service depends on ur area, if ur a diy guy u can always do it on ur own. Price to check usually from RM 50 - few hundred depends on where and how they charge labour. Some places very friendly, don't mind if u bring ur own parts or buy from halfcut shop while others will insist u use the parts they source from.
---------- Post added at 07:30 PM ---------- 6 hour anti-bump limit - Previous post was at 07:18 PM ----------
U just change ur clutch ? How bout the cover ? Bearing ? Mind givin more info bout ur car ? Which type of 4G93T ? CM series or CD series ?
One thing u can try, release ur clutch without stepping on the accelerator, slowly release ur clutch try and listen if got any funny sound ? And how ur car react ? Is it very jerky ? Then next try to accelerate abit, around 1k - 2k while releasing ur clutch try to notice anything weird ? Since it's a new clutch it might require running in as well, dun "race" ur clutch drive so much b4 5000 miles or 5000 km according to exedy. "Race" as in drag racing ur clutch rev high high then release the clutch.
Another thing is r u sure the sound is from ur clutch ? It could be something else like mounting or absorbers and so happen those parts loosen or worn out at wrong timing.![]()
