4G93T Club
hey guys im new in gsr...just change my wira 1.6 to gsr....wanna change BOV but may i noe that u guys use wat to stuck into de intake hole that for de ori BOV return....?thx
u just use battery to close it....use the big type battery..
dunno about that....been using for a year on my 63t....din explode yet...
how high r u boosting dat makes u think the stock oil pump unable to support?..
wanna boost til 1.2 n thats no place to fit de turbo cuz oil filter is blocking
---------- Post added at 11:46 PM ---------- 6 hour anti-bump limit - Previous post was at 11:44 PM ----------
okae..i'll try it..thx alot
haha..i definitely dare not, would pay machine shop to fabricate 1 for me..
hehe...now not using anymore since change to s/steel intake already....
kienyee :- don't forget to secure it properly....with clips
hi all,
sorry for interrupting, really need help with my evo 7 GTA, 2 days ago when i cruising around shah alam, sudddenly my engine warning light appear. After around 15-20 minutes the light disappear. What could be the reason? Can i get my evo to be scan since the light already disappear? please help me sifus -sifus.:adore:
hi all,
bro i think there are many evo sifu at MLOC forum..
thanks ehdrian, will try there also.
---------- Post added at 12:30 PM ---------- 6 hour anti-bump limit - Previous post was at 12:28 PM ----------
just notice this is 4G93T thread, not 4G63T thread.. aiya, my eye oredi alignment lari. Sorry guys!!!1
Hi all sifu, is 4g93p driver side drive shaft same wit gsr? D short wan which is without hanger. Thx!
Hi all sifus, need you help..M using Gsr Rs,recent Mods...stainless steel piping,tial mvs,fuel regulator however j have overboost issues.Currently boost can go up to 1.5 bar...any idea what can cause this problem....Foreman says maybe the main outlet of the turbo is 2 small so they advise to pull directly from the intercooler piping to the wastegate..can that solve my problem....Please help sifus...thanks
Hi guys,
sorry for tumpang thread, anybody can help me with idling problem on my 4g93t? too much vibrate. for info, i already service the throotle body, check vacuum leak, but the engine still in vibrate when idle. has increased the timing still can't tackle the problem.:banghead: any idea we can share?
Regards
hehe newbiw here
---------- Post added at 09:55 PM ---------- 6 hour anti-bump limit - Previous post was at 09:46 PM ----------
u tial mvs using wat spring rate ooooo???? use those 1.0bar enuft lo...or try connect back u ori acuator
hehe newbiw here
Bro using 0.9 spring rate....it is not the spring rate problem i guess...
no ecu managment control boost until 1.5BAR still smooth mehhhh,wont lag mehhh???
ori acuator hole lehh?? weld to jam jor?
---------- Post added at 04:37 PM ---------- 6 hour anti-bump limit - Previous post was at 04:21 PM ----------
bro using 0.9 spring rate....it is not the spring rate problem i guess...
u tial wastgate is ori or china geh?? china geh very easy pecah 1.....
Hi guys,
Regards
using any adjustable cam pulley? ur mounting all ok r?
---------- Post added at 10:11 AM ---------- 6 hour anti-bump limit - Previous post was at 10:05 AM ----------
ya you should check ur wastegate first if got problem....
Guys, one foreman said maybe my pioston compression is 2 high causing overboost..might be due to metal gasket....=S
thanks bro for the reply, nope bro, everything standard..mounting just change, someone has suggested me to change the fuel pump, their reason is the standrd pump can't support the press? is it true? i'm still using old rb nissan pump?
i'm not sure about the fuel pump....I've got a fren using vr4 turbo engine with 1.6 wira fuel pump only.....no vibrate what so ever.....
have u changed ur timing belt recently..??
---------- Post added at 08:32 PM ---------- 6 hour anti-bump limit - Previous post was at 08:29 PM ----------
do a compression test to be certain....it's easy to do if u have the tools for it...
checked ur wastegate already? ur wastegate open or not when ur boosting...??
[/COLOR]
checked ur wastegate already? ur wastegate open or not when ur boosting...??[/QUOTE]
Yup planning to check the compression next week but just to ask if overboosting can be cause by a compression issue.
Wastegate not opening also =(....
