- Joined
- May 7, 2006
- Messages
- 1,030
- Points
- 1,648
7.2k cut off? mine mivec 1st version cut at 8.2krpm :) get it check guys :)
im using mivec 10k rpm meter...wat meter u using? stock red meter with 10k rpm? i can share my experience here when i play mivec ck on my wira, i use normal 4g91 ck meter or ori wira meter, the mivec will not kick in, i dunno why, but after i changed to mivec ck ori red 10k rpm meter, even though it is semiauto meter, i throw away the auto bulb and use for my manual mivec, the mivec still kick in, cut is normal 8.2krpm
hello guys....good morning.... i using MIVEC ecu 7035 black top.. ECU got problem.. can the ECU 4828 use in my mivec... any problem..
please reply...
---------- Post added at 11:10 AM ---------- 6 hour anti-bump limit - Previous post was at 11:07 AM ----------
thank you...
i see...i think its hard to get a confirm good ECU since dont have a friend using this engine yet...
i think i need to check the plug 1st...what type of plug suitable for mivec?...Denso iridium IK22 ok or not?...
no check engine light at the moment...
---------- Post added at 10:32 AM ---------- 6 hour anti-bump limit - Previous post was at 10:30 AM ----------
u repair it or bought other ECU bro?...Hello.... My ecu settle....hahahaha
Similar threads | |
