If youre using the roiginal Evo5 gearbox, this gearbox already has double syncros. However if youre having difficulty in shifting, you may need to change to a different oil, if that doesnt solvethe problem, you may need new syncros. Please contact me if you need more assistance.
Ok,found this article about how to make twin muffler/exhaust system that is consist of s-flow and straight flow at the same time.
but the problem is i dont know where to find the parts and if i can use another part...
My started motor is giving some noises during cold start after the engine has started. It has a sound like a loose alternator belt for less than 1 sec. Anyway, I was told that it is not a problem and...
I bet y'all know the MUT, a bulky hand device that so-called tuners connected via a connector to ECU and was used to 'tune' engines (with stock standard ECUs, especially local cars).
