Should be no problem with honda rotors. A lot of people used to tell me the rotor warps easily, but from my experience, not an issue, usually it wears out, and only then it starts warping.
guess there's always exceptions to the rule :P...except mayb the current honda accord rotor....![]()
bro...this is my 15" rim with BB1 brakes
http://img24.imageshack.us/img24/5020/xbrakes.jpg
the clearance is already pretty minimal due to the calipers... my balancing weights scraped the calipers and now all come off already...
so if u go bigger rotors... i dont think its gonna be ideal
but then this also depends on the interior design of the rims...some 15" rims can clear the BB1 rotors with no issues
Im not sure about the knuckle bro....ex-owner of the car installed it...so it came with the car when i bought it...
My rim is 15*6.5 +40...so ur +35 offset should clear la i think
How much u bought ur disc n caliper? N where u bought? I think i my rotors kinda warped....so might need to replace...but wanna try skimming first....
LOL...yeah man...damn close.... think ill try to take a pic of the same angle as urs (with regards to the balancing weights) and post up...see how much clearance i actually get...coz i oso never actually seen it before heheheh
RM530...is really a bang for buck setup. just need good pads...and mebbe hoses...
anyone seen any other rotors for bb1 thats crossdrilled or slotted or both?
been trying to find but havent had any luck...
any idea how much is the Endless 500c pads? wats the model name ah??
i have a set of BB1/BB4 disc rotor....
if still interested pls pm me..thanks
Not so sure about the model name but blue color lo. Heard is RM1 per 1c. So 500c is RM500....
---------- Post added at 07:03 PM ---------- 6 hour anti-bump limit - Previous post was at 07:01 PM ----------
Your disc rotor is already slotted? Comes with original brake pad or performance brake pad? And also already modded the PCD hole?
How much want to sell....![]()
crossdrilled and slotted (inside n outside) disc rotor only....already modded to pcd 100 so is PNP to any 100 or 114.3 hole knuckle....rm200
Where's your location? Btw, the disc is still thick or thin? And also skim b4?
u gotta understand how brake actually works,my fren.....sorta 4got my science oredy but if i'm not wrong,brake works by converting kinetic energy(movement/speed of d vehicle) into heat...so,as long as ur brake system can convert d kinetic energy into heat fast enuff,they shud work fine.....but of course,everythg has it's working range.....once u've breached d limit,dat's whn u'll suffer frm brake fade......so,u gotta know,how fast can u go ard SIC n how smooth can u drive?2 person clocking similar lap time might haf different driving + braking style/point...so,brake A whc works 4 driver A MIGHT NOT work 4 driver B.....
