Your Preference Engine Choice for TE71 Coupe
EG9
2,309
37
Subang Jaya
Hi guys, the reason why I post this topic just for the sake of fun and to see the creativity in term of engine choice for FR platform.
Objective: To Build a Balance Drift and Track FR Machine.
Must consider about power output and Reliability of the engine setup.
The car come with 4AGE 16V TVIS.
Here are a few engine option that you have, which one that you'll go for?
A: Mod existing 4AGE 16V TVIS with aftermarket flywheel and standalone ECU with DLI.
B: 7AGE with 16V head with standalone ECU and DLI run with stock 7AFE flywheel
C: Balcktop 20V with stock ECU and aftermarket flywheel.
Which one will be your choice and is possible please stated what is the reason of your choice.
Thanks Q!
JaHaX
1,859
i would go for either silvertop or blacktop ... preferably blacktop ... match it with t50 gearbox and all
then put 4 throttle to it ... my original plan for my TE71 ...:confused_smile:
TRDae92
1,095
Malaysia....
www.cardomain.com
I will got for A, since 16v performance parts and upgrade item easy to find and price also reasonable. Also due to financial, mod original 16v TVIS can save some money too.
EG9
2,309
37
Subang Jaya
Great great...even take the budget limitation in consideration.
same as my concern as well.
shamburke
2,244
12
Subang Jaya
i definitely go for c.
b/top engine ... 4 turtle to blow....heheheeee...
EG9
2,309
37
Subang Jaya
alo Sham, blow apa tu? :retarded:
shamburke
2,244
12
Subang Jaya
heheheee... its actually 4 throttle open pot ler!!!!kasi itu nagin blow in faster heeeeee
scomatic
2,147
25
Kota Bharu, Kel
Take 16V and add aftermarket part lor...
16V TVIS had alot of cheap stuff, variaty and easy to be found le...
Just don't take 16V non TVIS is enough... Plug cable damn hard to be found... haha
Performance output, i don't think it can loose to Silvertop too much. But VS with blacktop, sure blacktop win lor.. But need to consider the cost of converting also ma...
Want power from 16V? add turbo lor... 16V are most easiest to convert turbo (easy to powerover drift) le...
And durability of 16V also better. then later balance money add the standalone ECU, external wastegate, new adjustable, Hi cam, 2way LSD and flywheel lor...
So conclusion, use existing 16V and add more aftermarket part better la..
TRDae92
1,095
Malaysia....
www.cardomain.com
EG9 bro.....ur topic become rojak now....ahhaahhaa......lot of idea instead of ur question asking for.
Come on all bro......just ans A, B or C and give the reason just that simple. Don't make EG9 hard to choose again with his financial budget lar. He already sold his belove AE92, now he wanna make the right decision without wasting much $$$$$....
EG9
2,309
37
Subang Jaya
hahahahha....yes yes....actually I considering that 3 options only. Force Induction is not in my list.
EG9
2,309
37
Subang Jaya
Actually I've done some research before I post it up. Just wanna see you guys preference.
7Heaven
7,373
Ipoh/Kelantan
hey hey finally ur project car gonna start huh.... hehehe...
y dun u go for BT? last time ur AE92 also use BT ma, so u should know more about this type of engine....
some more 20V lighter then 16V right?
for me i will choose the BT
EG9
2,309
37
Subang Jaya
But remember this is FR layout. My previous platform is FF.
Powerband for 16V and 20V is different
If purely for drift, for sure I'll just stay with option A which is more then enough.
The low end torque for 16V is much better then 20V although I can't deny that it will lose to 20V in SIC.
There are a few things to do to when trying to diagnose a misfire. All vehicles are different, but there are a few places to start.
1)If possible use an OBDII scanner on newer vehicles. The misfire counter function can help you determine which cylinder is behaving badly. Clearly this is not an option for all people and vehicles though.
Note)Even without engine scanners you can identify which cylinder is causing a dead misfire. Carefully disconnect one spark plug at a time. If the...
