whatever u say MASTERIf cannot titanium balls aluminium balls also can
Yes, it's achievable with the mods above.2:40 can be achieved without hondata and without the rollcage. Change the gear ratio and final drive, aftermarket ecu such as mugen etc, good suspension plus good suspension setup, adequate camber degree, better tyres. I think la.... what do u guys think...never tried my dc5 on track..so..its just an instinct... what say u guys?
Sifu Farouk has spilled out the beans...Print this and stick it on your dashboard guys!Actually, minimum requirement for dc5 to get 2:40 @sic :-
Your mods/setup should make your car/you: able to get 185km/h at front/back straight, trail brake turn 2,4,9, late braking + trail brake turn 1 &15 , vtec on from turn 5-6 (4th gear), vtec on at corner exit turn 4 (3rd gear), vtec on at corner exit turn 9 (2nd gear), 4th gear after turn 11 continue 4th gear turn 12-13, vtec on at corner exit turn 14 (3rd gear).
Use full width of the track + correct racing line is a must. You'll be smiling upon returning to pit. Hope this helps.
Hahaha...
---------- Post added at 04:39 PM ---------- 6 hour anti-bump limit - Previous post was at 04:05 PM ----------
---------- Post added at 05:44 PM ---------- 6 hour anti-bump limit - Previous post was at 04:39 PM ----------
Superb recipe for fast times at SIC!! :top: Totally agree!! Haven't manage to do all of it, but totally agree ... turn 12-13 is the bestest corner :top:Hahaha...
But this one arr... you gotta be doing like 145km/h++ maybe here. With car understeering here, it really requires titanium balls...vtec on from turn 5-6 (4th gear)
Maybe next time bro, with something a little bit newer :top:Lan, need to lower down the vtec point to 5200-5500 baru syok to execute corner
Totally agree lan, you must get a good suspension set-up to reduce understeer. Hey, my car doesn't understeer much turn 12-13. Oversteer adalah so I just floor here:top:
Turn 7-8 is taken in 3rd to get good exit speed out...
VTEC point is ideal at berapa bro? 5200 maybe?? mine at stock 6000 is really frustrating sometimes
Yup you're right meor, like T2 johor circuit. My car with stock ecu 6k vtec very frustrating at 9,4, 6. Turn nine have to wait 2s and turn four 1s. Turn 6 i must really have a good line otherwise oversteer at apex and must countersteer so i lose time 1s here. Imagine if i can save 4s totalT12-13 if taken correctly on 4th the car will slide to the right (kinda scary!) but it'll be on the line again on u throttle on. Juz like T2 at Johor circuit...
T7-8 can go on 4th if you have balls like Zane Loo.. Hahaha.
Trail braking for an experienced MME driver like Farouk should be easy peasy.. Haven't really tried braking in corners anywhere yet..
Turn 7-8 i consider it special..its called double apex...there are a lot of variations to the corner entry and gear. Good overtaking corner if you master it. For light mod cars 3rd gear is the best but if you have more power, good front roll and grip then 4th gear possible. This is fast and good..1s saving here. Otherwise you struggle at corner exit.what about turn 7 and 8?
---------- Post added at 06:31 PM ---------- 6 hour anti-bump limit - Previous post was at 06:30 PM ----------
one more thing...trail braking is not easy...
Alamak...sayangnyaMaybe next time bro, with something a little bit newer :top:
--> http://www.zerotohundred.com/newfor...975-2002-2004-jdm-honda-civic-ep3-type-r.html
heheh.. tulaa, u dont have FB ko kan IR sibuk skang...lan we have known each other for 15 years why tak cakap you want to sell your car lerrr??? like dis i also want to sell my DC5 laaahhhh
ok, sell dc5, kite main satria neo plak jom?
