Wira Rear Lamp Question
Which means they can double up as brake lamp and night lamp at the same time?
Usually are like that even VR lights are like that. Some cars of course have separate night light and brake light especially newer cars fitted with LED.....
RENESIS VIII
7,063
950
Ipoh
Mine got 2 bulb but not sure how to check if they are dual filament or not.
Need to taken out and see loh!
Single filament....5w for tail light, if 21w for signal light, some signal bulb comes in orange color
Twin filaments...... 21w/5w for brake/tail light
RENESIS VIII
7,063
950
Ipoh
Oh, can see there are 2 things inside the twin filament. I need to check mine and see. When I took out the bulb, I din't notice any bulb for signal light.
Nope. Mine got 2 light bulbs in there. big one for brake light and small one for night light like this:
Pardon the rust. This was before I clean it. You can't get this socket anymore at spareparts shop. :bawling:
As per bro. sanekit photo. Small bulb is tail light, big bulb is double filaments for tail and brakes....
RENESIS VIII
7,063
950
Ipoh
For those fully lit even on braking, means the small bulb should light up as well? Because the small bulb is on the inner side.
As per your photo, signal light on top.....lol
Located somewhere else then. :biggrin:
Yes. and the big bulb is outside. signal inside.
I thought signal is on above these lamp? :hmmmm:
sanekit
Dec 9, 2015
1,616
157
663
sorry. the small bulb is the night light. big bulb is brake light and night light. so at night, both supposed to light up and the big bulb 2nd filament will light up when braking. :adore:
RENESIS VIII
7,063
950
Ipoh
So, for those that lit up on inner side upon braking, could it be that they changed their small bulb to large dual filament ones?
Fully lit means both bulbs are twin filaments loh......:driver:
RENESIS VIII
7,063
950
Ipoh
This is one weird case here. Instead of brake lamp at outer side, this one is at inside while outer side is not lit.
Hii all....
Currently i'm using Michiba 4350K/55w (Super White) bulbs in my headlamp. However, izzit will damage the plastic cover and reflector of the headlamp (plastic type) for long term use??Hope someone can give advice. :angel_smile:
