Wira 1.5 convert Rear Disc brake PRO!!
sicness80
70
Hi to all expert,i had converted my wira 1.5 sedan rear brake drum to wira 1.6 ori rear disc brake,all the PROBLEM is handbrake totally NO FUNCTION!!i already replace the new handbrake cable left & right,n done the disc rubber repair kit.At 1st become fine,but after 1 month become no function again.i have to gear in to park my car even in house parking.can anyone tell me the pro or intro any workshop know to repair it?i had tried many workshop near my place but NO ONE can fix it n give many excuses:mad:, tq very much.:adore:
ToY_mAcHiNe5
95
1,508
well, the problem doesn`t happen to my satria. I do convert my 1.3 drum to mivec rear disk, so far no problem, and the handbrake was totally working fine.. mybe u can check ur master brake pump, the stock master brake pump can`t pump the oil to ur rear disc. And also please do check if their any leak or stuck in ur brake host. do 'bleeding' process to check the pump and host.
and don`t forget to check the brake piston. Do service a bit, cost you around less than rm20 to buy the brake kit.
PocketRocket
'(00) Mod'er
11,164
953
3,213
Up Yours
nothing to do with the pump or the lines or the fluid....
handbrake is cable related
fadlie
68
1,508
yup....handbrake totally use cable...not related with any fluid/master pump....
las time same problem happen to one side of my kancil rear disc...workshop around kl said canot repair, finnaly
send it to a small workshop at my 'kampung'....and he fixed the caliper, total rm5 only....
yashiofactory
328
yeah your handbrake are totally using cable the best thing is please check ur piston maybe need to change the seal.......n please reminded that if you using those rear disc brake its not really feel the same as you using the drum bro...anyway cheers
sicness80
70
thx for all reply..i ahd change new handbrake cable left n right n done rear disc brake piston rubber seal.but still the same..suspect is caliper pro..sigh..:banghead:
PocketRocket
'(00) Mod'er
11,164
953
3,213
Up Yours
try to remove the caliper n wash it down n re-lube it again ler...piston may be jammed
The Marketplace Top Posts
Few month before, the engine of my car got heated when am stuck in a jam in KL and now more often it happens when the car remains almost unmoved/ stuck in jam. But when the car is moving (say 60km/h) the engine become cool again after few minutes. According to the suggestion of my friend i changed the gasket and clean the radiator and also changed the cooling fan. But i am still facing the problem. it mainly happens in daytime but in night/rain the car is ok.
Can any expert help me to...
