wira 1300M need help!!
jedi
108
4
question 1:
what is the black rubber that looks like a sponge ? what if I did not replace it when it was thorn and what is the effect?
question 2:
something seems like leaking, can anyone know what was that?
thanks a lot to all
blackend
395
8
Johore,
for pic no 1,where exact position it located?
maybe, u should zoom out your pic
EvolutionZ
5,000 RPM
5,027
1,448
can u take the pics a bit far, jus to see what is the position, it looks like drive shaft cover, can be power steering rod too, pls zoom out.
for the 2nd pics...leaking at yr brake servo, if i not wrong..go get mechanic check asap...brake is no joke bro...
blackend
395
8
Johore,
it doesnt matter where it located,u must replace the rubber cover when it worn out as soon as possible.otherwise,the part inside will contaminated with foreign particle n dust
jedi
108
4
thanks for all the advice
pic 1 my mech say its the steering rubber, replaced it.
pic 2, i haven't check. but since it suspect is brake then i better get it done fast.
thanks bro!!
ken12292703
Drives a shopping cart...
1,542
8
5,138
SoMeWhErE
For the brakes, you don't need to change the whole pump if cylinder not scratched, worned or teared. Just get a service kit to replace all seals and rings. Should be much cheaper. :love:
Bump: For the brakes, you don't need to change the whole pump if cylinder not scratched, worned or teared. Just get a service kit to replace all seals and rings. Should be much cheaper. :love:
zendengoh
155
KL Kepong
www.zhapalang.com.my
the original proton brand new brake master pump not over rm100, if interested can call me up.
The Marketplace Top Posts
will we get better handling with the anti roll bar connect to absorber?
or connect to lower arm bar better? :huh:
